Posting some scans done, one a year ago and two this year in August.
I cannot see any way to change things.
In one controller I get to chose between 2 axles, front and rear, light or heavy load and the default setting for the tire pressure is 5.5 bar. Maybe this needs setting to a much much lower number, I just see that 5.5 is 79.7708 PSI. Maybe set this to 2.0 bar which is 29PSI
Am I guessing right???
My 3 scans:
June 13-2017
Address 03: ABS Brakes (J104)
1 Fault Found:
02214 - Tire Pressure Warning
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 205
Mileage: 24539 km
Time Indication: 0
Date: 2017.03.16
Time: 09:55:19
Freeze Frame:
Count: 2
Count: 14
Count: 4096
Count: 16401
Count: 43520
Count: 768
Count: 0
Count: 0
Address 65 Tire Pressure (J502)
2 Faults Found:
01521 - Sensor for Tire Pressure
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 19381 km
Time Indication: 0
Date: 2016.11.02
Time: 15:08:11
01325 - Control Module for Tire Pressure Monitoring (J502)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 19381 km
Time Indication: 0
Date: 2016.11.02
Time: 15:08:11
August 12-2018 This is after Phase 2 install
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 14
Mileage: 47377 km
Time Indication: 0
Date: 2018.08.10
Time: 03:24:59
Freeze Frame:
Count: 3
Count: 14
Count: 4096
Count: 16401
Count: 51712
Count: 65280
Count: 255
Count: 0
Address 65: Tire Pressure (J502)
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 34099 km
Time Indication: 0
Date: 2017.08.17
Time: 12:21:21
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 34099 km
Time Indication: 0
Date: 2017.08.17
Time: 12:21:21
August 29 -2018 This is after Phase 2 and Stage II install
3 Faults Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 47484 km
Time Indication: 0
Date: 2018.08.15
Time: 06:52:48
Freeze Frame:
Count: 0
Count: 14
Count: 4096
Count: 8194
Count: 45312
Count: 1024
Count: 248
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 57
Mileage: 47484 km
Time Indication: 0
Date: 2018.08.15
Time: 06:52:58
Freeze Frame:
Count: 2
Count: 14
Count: 4096
Count: 16390
Count: 45056
Count: 1024
Count: 248
Count: 0
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 69
Mileage: 47377 km
Time Indication: 0
Date: 2018.08.11
Time: 03:24:59
Freeze Frame:
Count: 3
Count: 14
Count: 4096
Count: 16401
Count: 51712
Count: 65280
Count: 255
Count: 0
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 47394 km
Time Indication: 0
Date: 2018.08.13
Time: 00:39:38
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 255
Mileage: 47394 km
Time Indication: 0
Date: 2018.08.13
Time: 00:39:38
