tdijim
My '96 B4V TDI needs a new oil feed line to the turbo. When I pulled the banjo connector bolt that connects the tube to the top right side of the engine, I noticed that it is hollow and has two openings at the top (of the bolt) I would think it is important that one of those openings lines up with the oil feed tube that runs to the turbo.
However...there is no mark, no arrow on the top of the bolt. That made me wonder if the inside of the banjo connector is recessed and the oil will get to the tube regardless of the direction the opening faces.
I plan to file marks on the top of the banjo connector bolt and align one of the holes with the tube connection anyway, but I wondered if, in fact, it wasn't necessary. Anyone ever work on this?
Jim
Jim
