AgentE
I've ordered 2 and both have solid pulleys.
Should I install the solid pulley??
98 beetle
98 beetle
Thanks for the response!Well first, whose alternator is it? If it is not a Bosch, you'll be doing it again soon... send it back. You really need a genuine Bosch one.
For the 1998 New Beetles, most of them came with the early type Bosch alternator, with the square plug (Bosch # AL 0723X). These are often not readily available anymore, and are not cheap when they are. These do NOT come with a pulley on them, you need to install one (INA brand, the VAG number is 022-903-119-C).
The very late '98 NB, and everything newer, uses the later type Bosch alternator (Bosch # AL 0189X). And those already come with a new INA pulley installed. These have the newer type D-shaped plug on them. You can easily update to the newer style if your car originally used the older style, you just have to change that plug on the subharness. The compressor plug, and the oil pressure switch, are also the old style on these early ALHs. You can upgrade the whole thing with a new harness, but those have been spotty on availability lately.
Curious, what is the difference in the two styles of clutch pulleys? Or are you saying you have both solid and overrun clutched?I have both of the clutch pulleys depending on which car you have, and you can put the clutched pulley on where there was a solid pulley.
But again... you need a good alternator, not a Amazon, ebay or parts store one.
The ahu and early beetle is a smaller diameter pulley than the alh and later pulley. Actually, the ahu one is identical to the cvca/crua ea288 engine's pulley.Curious, what is the difference in the two styles of clutch pulleys? Or are you saying you have both solid and overrun clutched?
Yes, a one way pulley would likely have helped in that situation. Almost all new vehicles have them now, and some even have special ones which help in the start/stop systems.Hi
Interesting about the one-way pulley
Years ago I was running a bread truck with a Cummins 4bt engine which is basically the 4 cylinder version of the 6bt in (6 cylinder) diesel in Dodge pickup trucks and that serpentine belt tensioner would jump up and down a lot ..... It was scary to see how much it was jumping back and forth.... I often worried about it fatiguing and breaking because of it.
I remember changing out multiple serpentine belt tensioners and all of them would jump .... I never figured out why and ultimately just let it run with the jumping tensioner although I'm sure that wasn't good for it.
My guess is maybe that would be what it's like with a TDI engine without the one-way pulley fully working?
I never knew about the police back when I had the 4bt I'm wondering if I would have somehow installed a one-way pulley on that alternator if the tensioner would have stopped dancing on that engine?
Anyways based on my new found knowledge from this forum I'm guessing the one-way pulley is important.... My tensioner pulley doesn't dance around and I'd like to keep it that way.
Andrew
So what happens if you stick an ALH pulley on an AHU? Slightly larger an slower. Any down side?The ahu and early beetle is a smaller diameter pulley than the alh and later pulley. Actually, the ahu one is identical to the cvca/crua ea288 engine's pulley.
I keep both the alh-cjaa pulley, and the ahu/1z/early beetle, as well as many other ones, including the bhw passat, audi q7, v10 Touareg, etc.
The only downside I can think of would be the belt size may have to be adjusted a little for the larger pulley.So what happens if you stick an ALH pulley on an AHU? Slightly larger an slower. Any down side?
Just checking.The only downside I can think of would be the belt size may have to be adjusted a little for the larger pulley.
I haven't tried myself so I don't know if there is enough slack with the stock belt and tensioner and the larger alh pulley. I have a pile of both of them in stock, so I just use whichever one is for the vehicle I am working on.
The rpm will also be a little bit lower for the alh pulley, which would result in slightly lower idle output, but I doubt it would be noticeable.
I guess for me, I think why should I use the wrong one when I have the right one thats the same price.Just checking.
I’ve been doing that on the 1Z Passat with the same belt. It does wind up the tensioner a little bit more. I altered the tensionrer to lessen the tension but don’t know that it was all that necessary.
TrueI guess for me, I think why should I use the wrong one when I have the right one thats the same price.
Yes. I have the one for an audi q7, its slightly bigger. Also several other options I likely could find.HI,
Since different pulley sizes were mentioned earlier, is there a one way pulley that can be used on an ALH enguine that is slightly larger than stock ?
If so where from / /part number ?
Andrew
Hi,Yes. I have the one for an audi q7, its slightly bigger. Also several other options I likely could find.
Send me a pmHi,
What kind of size differences are we looking at stock VS the Q7 Pulley ?
What other sizes are available as a bolt on option?
Andrew
Are you able to explain the rational behind the pulley size regarding the car that it is on? Why does one car application want to spin it faster than another?Send me a pm
I am not 100% sure why, but I believe in part it could be because of the crank pulley size, but the alternator design is different as well. Often they are engineered for the specific vehicle, and idle speed, crank pulley size, alternator size and design, and all that are factored in to determine what the ideal rotational speed of the rotor would be, and thus what pulley size it uses.Are you able to explain the rational behind the pulley size regarding the car that it is on? Why does one car application want to spin it faster than another?
