Andrei Rinea
- Joined
- Jan 21, 2002
- Location
- Europe, Romania, Bucharest
- TDI
- VW Tiguan 4Motion 2.0 TDI 170HP (engine CBBB)
Introduction:
110 kkm
Bought 2nd hand 94 Passat TDI, changed (some idiot mechanic did it) TB only (tensioner was not)
118 kkm
Crank shaft wheel got loose and allowed the TB to skip 1 tooth. Car become shtty to start. Good mechanic changed the TB, tensioner, new crankshaft pinion (toothed wheel), crank shaft re-leveled (it became rounded-like).
Car did not have one problem since then
137 kkm = present
No problems. Not even at -17 C degrees the car starts well. Just my concern if the mechanic did adjust the timing belt tensioner correctly since I can't remember that and can't track him yet.
I will take off the upper cover of the timing belt and look at the tensioner to be correctly adjusted. I have seen the drawing from the manual on how it should look if correctly adjusted but
I NEED A REAL LIFE PIC ON HOW IT SHOULD LOOK because it is easier to compare with the reality.
If it_is_ok_adjusted then end_of_story
else what should I do? Can the tensioner be adjusted correctly without messing the whole TB? (I mean without re-changing the belt and all of that stuff?)
TNX!!!
110 kkm
118 kkm
137 kkm = present
TNX!!!
