pyromancer
I've had an issue with low end lag on my car since I have installed this turbo and tuned. Recently worked with a tuner to try to correct this issue a bit, as well as not meeting the requested boost, and the determination was likely something to do with my hardware. We were able to fix the not meeting requested issue. In working with them I made sure there was no boost leaks, vac leaks, made sure motion was good, cleaned the turbo, and tried adjusting the actuator arm shorter and longer multiple times without resolving things. I tried everything I could find to try short of messing with the stop screw. More recently I have started trading emails with a member here who is in the process of learning to tune in hopes he could point me to something hardware maybe I haven't checked. After reviewing logs, vac readings, and details about all the stuff I have tried to fix this issue he suggested the stop screw on my turbo maybe set incorrectly. The tuner also wondered if I had something wrong with my turbo, and in trying to figure stuff out myself, more then once I have wondered if my stop screw was off or something.
Turbo was purchased from a respected vendor years ago and I have never messed with the stop screw. Have always read you should not need to do it, and its not a great thing to do without a flow bench or Exhaust manifold pressure (EMP) gauges. As in it's an easy way to cause lots of damage to your engine or turbo. Looking for a way to check to see if I am set correctly it seems like you could pull the turbo apart and measure the gap in the vanes to set it. Or in searching here I have seen a few posts saying if you need to do it you can "Adjust set screw between 2 to 4 psi at 2000rpm when engine are hot with full vacuum on actuator (bypass N75)". Would love more info/details on that if its a viable way to check or set the stop screw. Under load? In neutral? Measuring with a boost gauge or just looking for couple hundred mbar while measuring block 11? I have questions.
So has anyone ever adjusted the stop screw without EMP gauges or a flow bench? Is there a relatively safe way to check the stop screw position without pulling and taking the apart the turbo? Seems like I have 4-5 threads showing but from reading not even sure that's useful, as length may not be a good measure due to variation in the turbo inner parts can throw that off. I'm tempted to see how mine is set vs. the 2000rpm thing above but again would love more detail on the procedure for that. Have also thought about backing the screw out half a turn and seeing if it might fix some of my lag but I'm kind of scared and really do not want to damage the car. Everything I have read has put some fear in me about messing with the stop screw. Car is an 01 ALH, VNT17, 1019 injectors, 10mm pump, Stage 4 tune.
