Think i have a duff one (implausible brake signal) but it seems to switch in VCDS ok
Could anyone explain what's going on here?
In measuring blocks,group 6....
I'm seeing 001
Clutch pressed i get 101 Which returns back ok to 001
Brake pressed i get 011 Which also returns back to 001
Anyone know what the 3rd 1 does?
I'm using a passat pedal box in a mk2 body (running an AHU engine)
I's been suggested that because the Mk3 has 3 brake lights and my Mk2 only has 2 then it's getting the wrong signal - does this make sense
I have 2 twin wire switches on the brake and no cruise control.When i increase the revs then press the brake or clutch nothing happens,should the revs die?
I'm seeing 001
