Rods can be bought hereDieselDub764 said:Hi,
Could you tell where can I get those ti valve spring, retainers and oversized pistons, forge rods and where can I get my crank stroked?
www.rosten-performance.com
I want oneshortysclimbin said:mk3pd you win a cookie Kerma at kermatdi also sells them for about the same costs as it would cost you to ship these puppies overseas fyi...
dieseldub764,
I would say until you are really pushing a vnt22+ you dont really need to upgrade the bottom end on your diesel. And this isnt a stroker kit its stock stroke because getting custom rods to stroke like that would be expensive and would limit higher rpms more where the bigger turbos perform better. BTW did you find out which tuning company you wanted to go with yet? you have some nice bolt on parts there that really need a tune to take advantage of any of them. Try that first and read the posts above yours of mine and you will understand why I am not "giving" out all the info. I dont want people going out and spending all the money on this stuff to find out it doesnt work in my block. Just because It "might" fit doesn't mean it is designed for what I am doing.
Ok enough on that subject. you guys want more pictures and progress right? So here is a picture of the cleaned new crank next to the old one.
For everyone else asking these same questions please note you would get the same response as the last two. So I am just going to ignore them now.
Thats pretty damn good because 2200 is not bad at all and have a about 300 whp thats about what 13 secs in the 1/4 mileshortysclimbin said:Yes VT has very many rusted mk2s here but nothing that doesnt have duct tape and spray foam holding them together for inspections.
Total weight I am shooting for 2000lbs but that many be to light. If I could get it down to 2200 with better weight distribution I would be happy. Especially considering the cage, and heavier engine...
More like 11sdroppedjet said:Thats pretty damn good because 2200 is not bad at all and have a about 300 whp thats about what 13 secs in the 1/4 mile
I meant the generator and air compressor.shortysclimbin said:Yelram, as far as costs... Dont ask. More than most would budget for an engine build. I decided because I am single and dont have kids now is the time to play with projects like this..
You should convert to solid lifters and regrind your camshaft to a more "flow friendly" profile.shortysclimbin said:mk3pd you win a cookie Kerma at kermatdi also sells them for about the same costs as it would cost you to ship these puppies overseas fyi...
dieseldub764,
are you going to go w/lightened flywheel and balance the rotating assembly w/ pistons/rods too ?shortysclimbin said:mk3pd you win a cookie Kerma at kermatdi also sells them for about the same costs as it would cost you to ship these puppies overseas fyi...
dieseldub764,
Take a look over at Ferrea for springs.DieselDub764 said:Hi,
He need higher spring rate for preventing valves to blow open due to high boost pressure,not for controlling valve float at high rpm.rjr311 said:Take a look over at Ferrea for springs.
http://www.ferrea.com/products.php#vsprings
or
http://www.racingsprings.com/valve-springs.htm
However if you read "Myth #4" http://www.stockcarracing.com/techarticles/general/scrp_0608_valvetrain_myths/index.html
you will see that instead of going with Titanium valves the recommendation is to do beehive springs.
If you have some more time . ( and yes I know our engines are not V8 pushrods )
http://www.carcraft.com/techarticles/116_0402_valvesprings/index.html
http://www.babcox.com/editorial/ar/eb50354.htm
Not in a 4 cyl inline engine,noRub87 said:Won't it be out of balance if you shave alot of the counterweigts and use the stock mass pistons and connectiing rods?
All that parts pistons, rods, crankshaft has to be weight matched with tight tolerance just a crankshaft need to be dynamically balanced before it has to be fitted to engine. So do not worry with lightweight crank.....Rub87 said:Won't it be out of balance if you shave alot of the counterweigts and use the stock mass pistons and connectiing rods?
Hi Geir! A lot of fun here, isn´t?mk3pd said:Not in a 4 cyl inline engine,no
Hello Marek.StingrayRT said:Hi Geir! A lot of fun here, isn´t?
Christmass time........I lanched some new projects for 2008........a new aluminium R5 tdi engine in 9sec zone and some 11sec 1.9tdi for friends.....and may be a new 4.0 V8 tdi from new audi A8.......a friend need minimum 600Hp from this engine....mk3pd said:Hello Marek.
Yes,i have to visit here often.
How is your Lupo doing?
So lets say I want to run such 12.5kg eurospec crank in a PD150 bottom end with stock pistons that have been slightly machined for lower CR.. maybe the H beam rods, not sure on that one..StingrayRT said:All that parts pistons, rods, crankshaft has to be weight matched with tight tolerance just a crankshaft need to be dynamically balanced before it has to be fitted to engine. So do not worry with lightweight crank.....
Rub87 said:So lets say I want to run such 12.5kg eurospec crank in a PD150 bottom end with stock pistons that have been slightly machined for lower CR.. maybe the H beam rods, not sure on that one..
[FONT=Arial, Helvetica, sans-serif]EFC 105 101 SC 955[/FONT][FONT=Arial, Helvetica, sans-serif]038, 06A, 06B[/FONT][FONT=Arial, Helvetica, sans-serif]95.5mm[/FONT][FONT=Arial, Helvetica, sans-serif]New Style Long Nose and Trigger Wheel, Super Light. 12.5kg[/FONT]
Should it thezn be necessary to have the whole crap balanced or not? Whit these dollar rates it's really kind'a attrictive to get one
Looks like you will be busy for some timeStingrayRT said:Christmass time........I lanched some new projects for 2008........a new aluminium R5 tdi engine in 9sec zone and some 11sec 1.9tdi for friends.....and may be a new 4.0 V8 tdi from new audi A8.......a friend need minimum 600Hp from this engine....
99% sure that is the same rods!mk3pd said:Looks like you will be busy for some time
I stick mostly to gasser engine's,i don't have enough knowledge on Diesel engines.
Do you know if the R5 Tdi use the same rods as 4cyl PD130,140,150 ???
Keep in mind that PD150 has a bigger rod journal,so PD150 rods won't fit this Eurospec crank.Rub87 said:So lets say I want to run such 12.5kg eurospec crank in a PD150 bottom end with stock pistons that have been slightly machined for lower CR.. maybe the H beam rods, not sure on that one..
