This am I changed the engine oil and filter in my 2006 Jetta TDi, started it up to check the oil level and topped it up to specific level. My wife drove the car few blocks away to get some lunch. She called me and said the car will not start. I went over and the battery was dead. I boosted it and drove it home. I charged it up and load tested it and and its dead. I bought a new battery and installed it and it fired right up.
1hr later I was out with the car, came out of the store and it will crank but will not start. There was a slight burning smell coming from inside the car near the fuse panel. I checked all the fuses and they are all ok. even the ones under the hood on the drivers side. There is a possibility i may have put a fuse in the wrong spot while checking them but slight chance.
I am lost here and need the vehicle asap, its the only one we have
any idea's what could be the problem?? from what I have read everyone talks about this 109 relay. I don't see a relay anywhere that has 109 on it. Is this an older TDi relay?
