I just flushed my power steering system (2004 TDI), and decided to use Pentison CHF 202 as the replacement fluid.I thought VW used the CHF-11S?
Searching the forums, there are a few others using CHF-202 for their pre 2006 vehicles as well.
ID Parts sells Pentosin CHF-202. Look at their application list.
http://www.idparts.com/catalog/product_info.php?products_id=1160
Here's the comparison.
Pentosin CHF 11S covers Volkswagen 1990-2005, Spec TL 52 146.00
http://www.pentosin.net/specsheets/Pentosin_CHF_11S.pdf
Description
Pentosin CHF 11S is a synthetic high performance
hydraulic uid for life-time application in modern vehicle
aggregates. Pentosin CHF 11S is especially designed for
hydraulics in the automotive industry with the highest
technical requirements such as in: power steering, level
control, shock absorber, hydro-pneumatic suspension,
stability and traction control, hydraulics for convertible
tops, central lock systems, etc. It is suitable for all
extreme conditions and guarantees full performance
from -40°C to over 130°C system temperature.
PRODUCT ATTRIBUTES
Appearance Dark Green
Density at 20°C 825 kg/m
Kinematic Viscosity at 100ºC 6.0 mm/s
Kinematic Viscosity at 40ºC 18.7 mm/s
Kinematic Viscosity at -40ºC 1100 mm/s
Viscosity Index 313
Pour Point -57°C/-70.6°F
Flash Point 160°C/320°F
Ignition Temperature 235°C/455°F
Pentosin CHF 202 covers Volkswagen 2006 - onward, Spec TL 52 146.01
http://www.pentosin.net/specsheets/Pentosin_CHF_202.pdf
Description
Pentosin CHF 202 is a synthetic high performance
hydraulic fluid for life-time application in modern vehicle
aggregates. Pentosin CHF 202 is especially designed for
technical requirements such as: power steering, clutch
hydraulic, electro-hydraulic mechanisms of convertible
tops, etc. It is suitable for all extreme ambient
temperatures and guarantees full performance from
-40°C to 130°C system temperature.
PRODUCT ATTRIBUTES
Density at 15°C 840 kg/m³
Kinematic Viscosity at 100ºC 6.1 mm²/s
Kinematic Viscosity at 40ºC 19.3 mm²/s
Kinematic Viscosity at -40ºC 1400 mm²/s
Viscosity Index 302
Pour Point -54°C/-65.2°F
Flash Point 154°C/309.2°F
Ignition Temperature 245°C/473°F
Important note on fluid compatibility
http://www.pentosin.net/pressreleases/CRP_101_Fluid_Guide.pdf]
If vehicle specifications state CHF 7.1, CHF 11S and CHF 202 can be substituted in place of, but not mixed with, CHF 7.1.
CHF 11S and CHF 202 are fully compatible and mixable. Pentosin CHF fluids should not be mixed with ATF fluids.
