megaladon6
Need some advice. Yesterday the manual transmission suddenly started grinding, going into 1st when moving. Could sorta so times carefully and slowly find a good spot with the shifter, but not really. About 10 miles later and almost home and it suddenly feels like the engine has lost power and is jumping around-chunking and clunking. Pull over, enfine is fine. Try to shift out if 3rd and shifter won't move. A hard tug and it pops out. Run through the gears ok, so decide to start out again. Still had some clunking etc but it mostly went away. But came back for a few seconds a couple of times. 2nd and 3rd gear, but never right around a shift. Yest drive this morning and no issues except the 1st gear grind-feels like there's no synchro. What do you think happened and do I need an immediate fix? Fyi, clutch is 4-5 years old, South Bend stage 2 with smf. Thanks!
