pawel
- Joined
- Apr 19, 2008
- Location
- Naugatuck, CT
- TDI
- '09 TDI 6 MT, Platinum Gray Metallic, Anthracite Interior
After replacing all rotors and pads I did follow the procedure to apply brakes and pulling PB. After applying brake and PB rear brakes were not dragging. However, after driving for few days I realized that rear brakes started to drag. So today I adjusted the PB screw all the way out. The rear brakes are still dragging.
Any ideas of what should I try next? Should I try to move the rear caliper pistons back again after I loosened the PB cable and check for dragging? Or should I consider replacing the rear calipers?
