Old September 24th, 2012, 07:50   #1
guillaumeber
Fuel Economy: Roughly 45 MPG
Default Rear caliper return spring (for e-brake) where to find!?!
Hello!
I have a small problem on my car! When I remove the handlebrake, the caliper sticks just a little, leaving the e-brake engaged slightly... just a bit! I found on google that once uppon a time, vw used a return spring on their calipers to help the e-brake lever to come back to it's complete original position. I would like to add this spring (which is not present on my car)... but I can't find them. My Vw dealer says they can't get them anymore. Anyone had luck finding them locally or online? reproduction maybe?
here'S a image.
thanks alot!
g.b.
guillaumeber is offline   Reply With Quote
Old September 24th, 2012, 12:04   #2
JC_1992
JC_1992's Avatar
I have this same problem, but only on my passenger side. I would love to try these out if someone can find them.
2002 Jetta TDI GLS 190,000miles, 5-Speed
Mods/Upgrades: Snow Screen Delete, FrostHeater, 1.8t Pancake Pipe, RC Stage 3, Titan 520 nozzles, 17" Goal Wheels, Koni STR.T's, TT LCA's, SBC Stage 2 Endurance
In the process: Upgraded Upper IC Pipping, OMI, Exhaust
JC_1992 is offline   Reply With Quote
Old September 24th, 2012, 13:40   #3
Alchemist
TDI(s): '04 Golf
This is where I got mine:
http://www3.ns.sympatico.ca/roseland/VWPartsA4.htm
Paul
I've learned so much from my mistakes I'm thinking of making some more.
Alchemist is offline   Reply With Quote
Old September 24th, 2012, 19:18   #4
deadend9009
deadend9009's Avatar
TDI(s): '03 Wagon
Guillaume! Pogne le no. sur le post au dessus du mien. J'ai pogné les miens au dealer. 7$ ch!
deadend9009 is offline   Reply With Quote
Old September 27th, 2012, 14:59   #5
JC_1992
JC_1992's Avatar
Anyone know of a source in the US?
Old September 27th, 2012, 18:00   #6
turbocharged798
turbocharged798's Avatar
Fuel Economy: 40-50mpg
Yeah, I would like to know as well. Tired of hanging parking brakes in the winter.
99.5 Black Jetta TDI; DLC1019 nozzles, G60/VR6, ASV .5mm pistons, EGR delete, ASR/EDL, bilstein TCs MFA cluster.. Beater car. 365K miles and climbing.
99.5 Red Jetta TDI. Saved from the crusher. 270K
04 Jetta TDI .MFA cluster, reverse light mod, bilstein TCs 200K.
turbocharged798 is offline   Reply With Quote
Old September 27th, 2012, 18:22   #7
Joe Gabura
TDI(s): 2006 Golf
Fuel Economy: 5.4L/100km city/highway
I bought a pair of those springs through the local VW dealer last April. Part number
7HO-615-295-A and 7HO-615-296
Joe Gabura is offline   Reply With Quote
Old September 28th, 2012, 15:41   #8
TDI Convert
TDI Convert's Avatar
Fuel Economy: See my signature for Fuelly data
ECS Tuning has the left spring 7HO-615-295-A here:
http://www.ecstuning.com/ES1218784/
And right spring here:
http://www.ecstuning.com/Search/Park...ing/ES1218785/
I am going to order two.
2006 Jetta: PD150 Intake and Injectors, R783 Nozzles, GTB1749VC, TD Stg 3 Tune, 3 Bar Map, SB Stg 3 Clutch
TDI Convert is offline   Reply With Quote
Old September 28th, 2012, 17:26   #9
Cleenlivin
1stvwparts.com.
The pricing is probably the best you'll find but the shipping charges might be the deal breaker...that is, unless you need to order some other parts as well.
Cleenlivin is offline   Reply With Quote
Old September 29th, 2012, 17:47   #10
eb2143
eb2143's Avatar
Fuel Economy: Lifetime average ~ 50 mpg
Thumbs up
Never knew these existed...
2001 Jetta TDI 5mt, 280,000 miles (bought new 02/2001)
Bosio Sprint 520s, Koni FSDs, VW HD Springs, 10mm spacer, Audi TT LCA bushings, 034 motorsports strut mounts, E-code lights, Audi TT "short"-shifter, IDparts rear sway bar, DG Panzer plate, Caterpillar 2µm fuel filter, Frostheater, GLI Recaros, GTI 3-spoke steering wheel, Audi S3 shifter, R-line stainless pedals
eb2143 is offline   Reply With Quote
Old September 29th, 2012, 18:10   #11
Garrett-TDI
Any dealer can get them.
Just a note though, the one in that picture the OP put up is not installed correctly. The coil of the spring should be on the forward side of the caliper, not the aft as illustrated. They tuck in nicely when installed properly.
Garrett-TDI is offline   Reply With Quote
Old September 6th, 2013, 15:06   #12
Thirstyturtle328
Thirstyturtle328's Avatar
Just spent 30 minutes TRYING to put them in opposite of the posted photo PER your suggestion. Doesn't work. Period. Took 20 seconds to put them in per the photo.
Please post your photo of them installed opposite of the photo.
2002 Golf GLS TDI 5MT
Bosio Sprint 520's, Audi 17x7.5 Fat Fives, Panzer Plate, CCV Mod, UltraGauge
Thirstyturtle328 is offline   Reply With Quote
Old September 6th, 2013, 19:50   #13
eb2143
eb2143's Avatar
No, it does work. Mine are in the tucked-in, forward position. It was a bit confusing and took me several minutes to get it right, but you know right away when it's in the correct orientation. I'll snap a pic now with my cell phone.
Old September 6th, 2013, 20:06   #14
eb2143
eb2143's Avatar
Here you go:
The biggest hint is to study the difference between the L and R hand side springs, and then use that observation to guide you as to the correct orientation. I believe it took some muscle as I had to compress the spring and engage the parking brake to get them on in the correct orientation. I'm assuming you know the springs are specific to the side.
This picture is the left (driver's) side caliper. I think I have my P-brake engaged.
PS - these springs were not strong enough to solve my sticking caliper in the winter time. I have a compromised parking brake cable boot (as you can see) though.
Old September 6th, 2013, 20:44   #15
Seatman
Seatman's Avatar
Fuel Economy: No idea
Hope you don't mind me stealing your pic but
Take off bolt 1 and get that lever off, take off bolt 2 and put it aside, there's a rubber seal below the lever under bolt 1, get it out carefully with a small screwdriver. Now put the lever back on and do the nut up, not fully, just enough to get hold of the pivot. Spray said pivot and work the lever back and forth, use the wind back tool and retract the piston then work the lever some more. Once it's all free put some kind of long term lube in there, replace the seal, the bracket and the lever and add the new spring. This will last a lot longer and give you one hell of a hand brake.
Seatman is offline   Reply With Quote
Rear Brake Caliper Removal ginbandit TDI 101 2 August 10th, 2011 20:24
Rear Brake Caliper Replacement PDJetta VW MKIV-A4 TDIs (VE and PD) 2 May 29th, 2011 04:55
rear caliper drag after e-brake adjustment - bad caliper? gcarl0 VW MKIV-A4 TDIs (VE and PD) 2 July 6th, 2008 18:01
how does the rear brake caliper work? VFchicago88 TDI 101 16 February 22nd, 2008 06:24
hand brake spring in caliper -=PYRO=- TDI 101 3 January 25th, 2008 18:36
Page generated in 0.16186 seconds with 10 queries
[Output: 130.27 Kb. compressed to 108.38 Kb. by saving 21.89 Kb. (16.80%)]
