I have the same car Dont sweat it dude, when i got that P2015 code the FIX is simply to go online & order one of these L shaped brackets i installed it myself you will need to remove the actuater motor wich is if i recal 2-3 bolts & slip that L bracket on the side of the motor and tighten up the screw very tightly dont wory about that silly spring it does nothing anyways. trust me its super easy. now the pcm may still keep the engine light on for awhile even after installation until it recognises it may take some drive cycles & some time but eventually within a week or 2 it will go permanetly out i think i had to waite a week for the computer to adjust. after that light has been out ever since. many youtube videos to see for help the other code could be that your EGR needs either a cleaning or replacement any decent tech should be able to get it off & look at it. posted the L bracket below to fix your P2015 code very common on the TDI 's good luck keep us posted.My 2012 Jetta TDi M6 with 112K miles is throwing code P0401 & P2015. and ideas on how to fix those? thx Super bike mike
I dropped the spring somewhere in the engine. Why do you believe it plays no roll? Does anyone no where I can get another?I have the same car Dont sweat it dude, when i got that P2015 code the FIX is simply to go online & order one of these L shaped brackets i installed it myself you will need to remove the actuater motor wich is if i recal 2-3 bolts & slip that L bracket on the side of the motor and tighten up the screw very tightly dont wory about that silly spring it does nothing anyways. trust me its super easy. now the pcm may still keep the engine light on for awhile even after installation until it recognises it may take some drive cycles & some time but eventually within a week or 2 it will go permanetly out i think i had to waite a week for the computer to adjust. after that light has been out ever since. many youtube videos to see for help the other code could be that your EGR needs either a cleaning or replacement any decent tech should be able to get it off & look at it. posted the L bracket below to fix your P2015 code very common on the TDI 's good luck keep us posted.
