zolorin
Hello all, this is my first time asking a question on this forum, so don't be too rough on me. I had been reading whole bunch of this forum for many problems in the past but now I am dumbfounded.
Ok, I have bought a 2000 VW Jetta TDI with 5 speed about a year ago. The PO have told me that he have installed a new clutch from the VR6, had replaced a turbo (gave me an old one) and told me that he can't keep his car because it was in a wreck and his insurance would not insure it with a salvage title. Price was right, I bought the car replaced the bumped, fender and a headlight and finally started to enjoy the mpgs (up to 54 on the highway). Resolved the check engine light with the glow plugs/harness kit and the car was very happy. So over the x-mas brake, 20K miles later, I have replaced the timing belt, water pump, cam followers, vacuum and fuel hoses, the 200K deluxe kit from boraparts.com This is not my first time dealing with the TDI since I have helped a buddy to rebuild an engine 4 years ago. All went well, all hoses, belts, accessories, and skin on my hands had been replaced. I have decided to change the thermostat as well -- just hate to have my investment to go up in smoke over a 20$ part. (which is an outrage since I am used to thermostat being $5). Anyway the TDI thermostat from wheler (spelling is off) did not fit and the PO had the single action thermostat from the 2.0L installed. So I have replaced with the identical looking one.
So initially everything looked fine however on the long drive to work a month later my car started to over cool (as the gauge would go below the 190 mark on the downhills). This is happening in south cal, no snow, just maybe a bit extra wind. So I was perplexed. A week later the over cooling issue exacerbated that my water temp rising to normal operation range went down to fully cold (fully left) and stayed there. Once I pulled over I touched the hoses and they were bone cold.
So two weeks ago I have replaced the 2.0L thermostat to a real TDI from wheler and the problem still persists. Now the temperatures are low almost all the time. I did notice that the lower plastic pan had several screws out and the radiator may be getting additional cooling because there is an easy way for hot air to escape.
I have replaced the water pump, and two thermostats and 6L of fluids and the engine is way way too cold.
a. is this normal?
b. is this because of the lower pan being not fully secured
c. is my egr being not as good -- it had been weeping some oil lately
d. my water pump running backwards
e. I am dreaming and I need to wake up from this nightmare
Thank you all
a. is this normal?
Thank you all
