MEgearhead
I have developed some play in the steering, along with a little noise. It's a click trying to grow up into a clunk as you quickly steer off-center.
The largest amount of play is in the outer tie-rods, but it's not at the ball end. It's at the rubber damper where the threaded rod connects. Using a long extension I have confirmed the noise comes from there also. Is that a common failure mode for these?
There is a small amount of movement at the lower arm bushings, but I think it might just be the compliance of the rubber. I had them apart to remove the cradle when I swapped the transmission and they looked in perfect shape. They were torqued properly (loaded), and I have verified they are still.
The upper bushings are checked, but have very little play. I am considering pressing new bushings in just so I don't fail an annual safety inspection. Are there any gotchas? Looks pretty straight forward.
The handling of the car has been deteriorating slowly over the past 10k, and I'd like to restore it back close to new. The struts/shocks are getting a bit soft, so I will be replacing them. I do have to say that this is the first car that has made it 225K on the original suspension/steering. I can't complain.
