INTRODUCING OUR LATEST PRODUCT, THE SMART SHIELD FOR YOUR JETTA, GOLF AND NEW BEETLE MK4
http://www.evolutionimport.com/smart-shield-for-jetta-jetta-wagon-golf-and-new-beetle/
Fits:
98-2010 New Beetle All Engines
99.5-2006 Golf All Engines
99.5-2005 Jetta All Engines
99.5-2006 Jetta Wagon All Engines
2004 Golf R32
All 2.0 City Golf & Jettas (Canada)
PRODUCT DETAILS OF THE SMART SHIELD
This Smart Shield was 1.5 years in the making. Hundreds of hours were put into designing, fitment, testing and production. The end result is a superior shield that's extremely tough, durable and functional. The material used to make this shield is space age having a Tensile Yield of 3600 PSI. It has a wear through ratting more than 10 times that of steel in the same thickness. What this means is if you were to drag and object across it, it will take over 10 times longer to wear through then steel. The Smart Shields normal operating temperature is -90.5C to +125.5C so whether your using it in Anchorage Alaska or Death Valley California this shield will not fail. Our Smart Shield was tested through this past winter and never cracked or failed like the OEM cheap plastic sound dampener covers from VW. Here is some additional information on the Smart Shield:
https://www.youtube.com/watch?v=cErpe0aynK0
Shipping Information: This product is considered oversize by Fedex and has a $9.50 Additional Handling Fee per shipment. If you would like to know how much shipping will cost simply add the items you would like to purchase to your cart. Then click "View or edit your cart ". Then click "ESTIMATE SHIPPING & TAX". Enter your Country, State/Province, Zip/Postal Code and then click the button labeled "ESTIMATE SHIPPING & TAX" and it will give you the shipping cost. This is the quickest way to quote you on shipping costs. Please use this method before emailing us as it can take up to two days for us to respond to the email.
Fits:
2004 Golf R32
- Made out of Space Age Resin.
- 4.8mm Thick ( 3/16" )
- Ribs added for superior strength every 2.75 inches.
- Weighs 5.1 Lbs (5.5 Lbs including hardware).
- Oil drain and filter change access holes for all engines.
- 5 minute initial install and 1 minute to remove or replace next time.
- Extremely high wear resistance.
- Corrosion resistant fasteners
- Drain holes for fluid accumulation.
