TurbineWhine
Car is an 03 NB, 5 Speed with 70k on the odometer. Car runs fine has and has normal power. The engine is basically stock from a performance standpoint. Today my wife noticed a noise coming from the engine bay. Got to checking and it appears to be coming from the IP. If the engine sits for about 3 minutes, it take about 30 seconds for the noise to start when the engine is cranked up. This is very repeatable. The noise almost sounds like the pump is getting air as it is not a steady sound and will completely go away for a fraction of a second at random times. It really does not sound like a bearing and is definately not in the serpentine belt path. I have also replaced and ruled out the top TB Idler pulley, as it is very close to the noise and the TB is due in about 10K miles. I found a thread that JSRMonster had replied to concerning the case pressure relief valve and checked that. It had walked out a very small amount and I reseated it and no change to the noise.
The fuel filter has less than 8K miles on it, so I don't think it should be the problem. Fuel used has been strictly D2, not that I have anything against BioD, other than its price tag in my area. Back to the noise, it sounds very much like I would imagine a pump sounding if it were getting and trying to compress air, yet the engine runs flawless at idle and under power. Obviously there are no engine codes set and timing is dead on.
Any thoughts or similar experiences out there?
Thanks,
TW
Thanks,
TW
