New Mass Airflow Sensor = Best upgrade yet!!
JettaTDI
CT-CA
'02 Jetta, '03 Golf
I just wanted to share my discovery with you guys. I have an '02 Jetta TDI with 215,000 miles on it. Over the last year or so, I kept getting overboost faults if I drove a little too aggressively. I had the intake cleaned about 6 months ago, but I only noticed a mild increase in power. It would still overboost though.
On a whim, I ordered a new MAF sensor online. Keep in mind there were no MAF fault codes or any other codes, unless it overboosted (PO234)
What a difference. The car is much quicker now, & does not overboost. It's also louder on the intake side. You can hear the power increase. I'm also getting about 40 more miles per tank.
The new sensor looked a lot different too on the inside compared to the original one.
BTW - the one I got from ID Parts was way less than the dealer part.
Great upgrade :cool:
jettawreck
Northern Minnesota-55744
2001 Jetta and 2003 Jetta
Bad MAF will usually never throw a fault code.
A new MAF will make quite an difference in performance from a failed one and solve some boost issues.
The new version do look a bit different inside with the extra venturi thing in there.
I think metalman has them for a bit less than IDparts, either way lots less than the stealership retail list.
Its fun driving again, I'll bet.
scooperhsd
Kansas City KS
The first time I did an MAF replacement - it was like a new motor had been dropped in place. i just recently did my 2nd MAF replacement - results weren't as dramatic since I caught the issue sooner.
Curious Chris
Pineview GA
Jetta Wagon 2003 RIP Rockford IL
When I bought my first TDI (1999.5)I though it had a rev limiter around 3000 rpm. Logged the MAF in VCDS (It was VagCom back then) and sure enough the MAF would hit 850 and then drop in a few seconds to 500. Yes no CEL as it was not a hard failure. New MAF and off we go.
Now on my 2002 I am on only my second MAF as I recognize the symptoms now.
chrisfiat
farmington nh
97 jetta
if you are hearing " a lot more intake noise" re check your installation and be sure your air box cover is installed properly
Midwesthick
Denver
A6, Q5, Golf
I fell my car is completely running amazing, how would I know if the MAF was bad? Is it just one of those things you change after you hit 200K miles or something?
jettawreck
No, not a scheduled replacement item. They fail sometimes at unknown intervals, but the replacements have been much better than the originals in the early TDIs. I've had at least one fail in each of the three ALH cars and all have been a bit different syptoms. You can log MAF data w/VCDS, but usually you get some gradual performance loss that it kind of hard to notice because it happens very slowly. One day you realize the car is much "doggier" than it should be/once was. Sometimes you get an almost limp mode effect above 3K. This is what the last bad MAF did in my '01.
Never had a CEL from a bad MAF.
Midwesthick
Denver
A6, Q5, Golf
word ok. I noticed today when I was in 5th gear and floored it around 60-65mph the RPM's climbed a little but the car took a second to get itself going, turbo lag or perhaps a failing MAF maybe???? sucks those things cost 200 bux
craig01b
Guelph, Ontario.
None
Not to my knowledge, unplug it,and drive if it gets better (although won't be as good as a healthy maf) its pooched.
Cleaning will help temporarily, but not for long....200 is cheap, the first one I almost got from a dealer, but balked was over 500!!!!! I ended up using a pierberg out of a mercedes, until the prices came down from vdub...
C
craig01b
Guelph, Ontario.
None
200???
038 906 461C
Bosch 0 281 002 757
Mass Air Flow Sensor Assembly
Updated Version, different design than older MAF, beware of some suppliers selling
the original version as an updated version, always check the Bosch part number to be sure.
( for all ALH Engines, new, not rebuilt )
$90.00
Bickford
Nictaux Nova Scotia Canada
2000 1.9 Jetta 2001 golf 1.9
i head the same problem with my TDI 2000 jetta mass air flow sensor went i got one for 120 bones but i head a grage in calgary alberta work on my car clamed i head a torn blater in my waste gate well the fixed that but never set my my car back up for boost so it was always over boosting i think it was around 28psi we head to back it to 24psi now shes like a new car till spring happy hunting people and ya there is a big differents be tween the old maf and the new one
Midwesthick
Denver
A6, Q5, Golf
that's clutch slippage
This is my 1st VW that I ever had clutch slippage with! also my other vw's were 1.8T's and 2.0T's and not a 1998 with 204000 miles with me being the first one to ever mod it. word, im so not worried now, easy fix. thanks man
hgsmith
TAFT, TN
2003 Jetta
I had the same problem, over boost and no codes for a bad maf. I changed all the vac lines (thanks paramedic). That did not help, but the lines need changed anyway. It is a 03 auto with 300k on it. Ordered an maf from metalman and the car runs great once again !!
2000BlueJ
Hebron Maine
2000 Jetta
My maf is smoked and it actually threw a code yesterday, p0101. Swapped in my friends from his golf and holy balls what a difference! Had to switch it back so now i have to leave it unplugged and wait til I get some extra coin :(
Biczek
SW Florida
96 Passat TDI Wagon '13 JSW TDI '14 Touareg TDI
How about us older '96 Passat 074 906 461
Anything cheaper than $196?:eek:
tvandermeuse
Wisconsin
98 Beetle
Just put in Bosch # 0281002757 at Rock Auto $70 (038906461C)
Seatman
Scotland
2007 Seat Alhambra 2L tdi
I had the opposite but only once, unplugged the maf and the car went like a pocket rocket lol.
That was a first and only for me and not my car, I think the guy still has it unplugged though :D
