timsch
- Joined
- Nov 12, 2009
- Location
- Brookside Village, Texas
- TDI
- 2003 Mk4 Jetta (blue), 2003 Mk4 Jetta (black), 2011 Mk6 Jetta, all manuals
I've had a 2011 Jetta TDI that has had the P1A58 code for NOx regen since I got it a year ago. I finally replaced the thermostat that wasn't reading high enough for the regen to occur. I took it out for an hour long highway drive where I initiated the regen cycle in VCDS when coolant temp was reading between 86.7 - 87.3C. As soon as I saved "1" as the stored value, nothing really happened on the VCDS to indicate it had entered into regen. I didn't know what to expect...
Anyway, I drove it as if it was in the cycle, watching MB104 for a change in status (0xFF02), but that never happened. That block just went back and forth between 0xFF01 & 0xFF10. None of the other fields ever changed that I recall. Here's a photo of the screen when I was driving.
Here's a photo of the window to initiate the cycle which I pulled up after the drive.
Any tips on what to expect when this regen cycle is occuring and how to check would be much appreciated. I'm not finding much info searching.
How do these load values look?
Is it a problem to have the cycle interrupted? I have about a 40 minute commute to work, a good 15 minutes of it which is on the highway that I could run the cycle. The remainder is on streets with traffic lights though, generally moving.
