rjsummer
My 2000 Jetta TDI has been running fine up till 2 weeks ago. With 335,000 KM on it, I was passing a car on the highway. I dropped down into 4th and floored it. After releasing my foot at the speed limit in 5th gear, the car kept accelerating as if on cruise. Cruise was off, and I fought the car with the brake, no help, pulled over, stupidly hit the clutch, it rev'ed up for a second as I turned the key off. It stopped.
Then it was hard to start. Finally started, and ran rough, then fine. Since then, it starts with the glow plugs at -20 degrees C but after about 5 seconds gets really rough and doesnt run evenly or on all cylinders. Lots of smoke out the tail pipe. After about 10 minutes of driving, (it gets progressively better as it warms up) it is fine and runs like normal.
Took it to the dealer. Glow plugs ... ok
Injection pump... ok
Timing ... ok
Fuel filter... they said it wasnt staying full, draining out of the filter overnight type thing. Replace the filter they said, so I did. No change. Took it back. They said my new filter was defective. They wanted to replace the filter. I said ok. They claim their VW fuel filter was staying full. But... no change.
Then they said it was the injectors maybe, they took them out and had them pop tested. Spray pattern was off a bit, so they said rebuild or replace. I replaced them with new ones. No difference. On the test drive they said the car took off on the tech. They said the turbo was toast, leaking oil caused the runaway events as it was sucked in the intake. They said on the last runaway the seals blew and so they put a new turbo on it. Still runs exactly the same as in the opening paragraph. 2,500 dollars later they say it must be a mechanical fault in the engine. They want to tear it down to check the pistons and rings and so on.
At this point they've had the car a week, and I'm bled dry of money. I told them to forget it.
Anyone have any ideas?
They claim a normal compression test is within spec but a cold test (which they admitted youre not suppose to do cause it can skew the readings) said there was an 8.8 bar difference between cylinder 4 and the rest , only when cold.
If the engine when cold is tighter fitting, why would it have worse compression cold?
Could lifters that are beat cause this and take a while to pump up to pressure? There is some ticking amongst the diesel sound.
No codes ever came up. When warm the engine did and now has normal power and gas mileage.
Any helpful advise would be appreciated.
-Jeff
Timing ... ok
-Jeff
