Mystery bolts
79TA7.6
Live: Wilbur/Creston; Work: Moses Lake Washington
2003 Jetta GLS 5 Speed
I pulled my skid plate off yesterday to do some work and I found two extra bolts laying on top of it. They have a 13mm head and look to be about 35mm long, though I did not measure them.
Now a few months ago I replaced the timing belt and the clutch. I looked around the trans and did not see anything missing.
Any ideas as to where they might go?
Dimitri16V
DE
01 Golf, 04 Golf
cover plate on differential ?
if they were still around , they were meant for you to re-install them :D
gforce1108
Newburgh, NY
04 Jetta GLS BEW, 03 Jetta Wagon ALH
the cover plate on the differential is secured with M6 bolts (10mm head). They looked like the two bolts securing the heat shield for the passenger CV axle, but I believe they are M10 (16mm head?). I don't remember seeing a matched pair of M8 (13mm head) bolts like that.
tongsli
Baltimore, MD
Keep the possible locations coming. After work I will try to look in all of the places mentioned, so long as I do not have to climb under or remove the skid plate. Can't do that in the parking lot.
Good luck, hope you get it solved
gforce1108
Newburgh, NY
There are 6 that are close to that on the transmission. Both ends of a bracket / support that go from the trans mount to the trans and the two that hold the slave cylinder in place (pretty sure one pair has a different design bolt head though). Right now my best guess is the two holding the power steering cooler lines to the trans?
