some_raisins
Is there a list anywhere? Things that are good to check on a 20 year old MK4 manual Golf TDI that are known to go bad? suggested preventative maintenance not listed by VW? Things that I have run into over the years:
- check/refill transmission fluid
- various places where air flows can get clogged - I'm not sure of exact locations
- glow plug wiring harness goes bad (faulty glow plug indicator in dash was fixed by replacing the harness)
- fender tips rusting out (I'm just letting this one go, but it is now into the rocker panels)
- wiring in grommets on both sides of hatch hinges severing (ground wire severed causes fuse to blow - remote key lock/unlock & windows won't work when this fuse is blown)
- MAF sensor (loss of power)
- engine thermometer (if it doesn't go to 190 & stay there, your thermometer may be bad)
- pin inside of ignition cylinder that goes into the ignition switch breaks off
- I saw another thread about the fans that cool the air conditioner compressor
