I’ve got an engine problem that I just cannot “debug” and I’m looking for suggestions
The engine is a 2.5L VW 140-5 marinized “ANH” that is the same 5-cylinder used in VW Transporters and other vehicles. The differences are in cooling – marine engines use efficient salt-water impeller-driven cooling rather than air, and the ECU has been modified to reduce the output to 140HP but to make the engine more reliable for maritime use. One example is the cut-off valve which is normally open and only shuts off when it gets 12V (you don’t want your marine engine to cut off in a lightning storm).
My problem is that once I advance the throttle beyond 1100RPM then, after a few seconds, the RPMs start fluctuating wildly and sometimes it sound like the engine is almost ready to cut off.
I’m at my wit’s end regarding what to try next! I still think it’s a fuel delivery issue but can’t think of what step to take next to locate the cause.
I have an extra small 12V fuel pump, would adding that in series in order to increase the fuel delivery pressure cause undue problems or make a difference?
I should add that I’m currently in wonderful St. Lucia. While a beautiful Caribbean island, the concept of “high tech” means something completely different here to what one would expect in the USA. I can’t get technical assistance and shipping in parts, even something the size of a spark plug, costs at least $200 in shipping. So I’m limited in what tests I can perform.
- I’ve got a registered VCDS-Lite version installed and have applied the “hammer mod” to make the idle IQ around 5-6.
- There are no error codes generated by the engine.
- When the engine is cold it will run at 1200 or 1800 RPM with no problem for a couple of minutes. I can hear the turbo kick in. But once the engine warms up it goes back to the fluctuating RPM problem and no power
- I can only run continuously at about 1000-1100 RPM
- I’ve got dual primary 30um filters with a manometer and have replaced the filters and show no back pressure/blockage
- I’ve removed the fuel supply from the secondary filter and when I turn on the ignition, I get about 250ml of fuel from the small 12V pump in less than 30 seconds.
- I’ve replaced the fuel filter between the fuel pump and the injection pump.
- The air supply is unblocked. The filter is clean, but I’ve removed the whole filter assembly just to be sure.
- I’ve removed the cut-off solenoid and cleaned the entrance with Q-Tips (no evidence of any debris) and made sure the spring has enough tension. I’ve tested the solenoid with 12V to make sure it activates.
- I’ve gotten a “cloned” ECU to see if I might have a broken ECU but that made no difference.
