1. Shifter Linkage
2. Left 5spd Axle
3. Right 5spd Axle
4. Dogbone (engine mount)
5. Clutch Slave Cylinder
6. Clutch Slave/Clutch Pedal Metal Line
7. Foam for Shifter
8. Clutch Pedal with Hose
9. TDI Starter (low km)
10. Shifter Weight with catch spring
11. Shifter Arm with catch spring and lock clip
12. Clutch Switch with Connector
13. Cruise Switch with Connector and bracket
14. Pedal Switch with Connector
15. 2 Relay 53 (one extra)
16. Shifter to Center Console Bracket
17. Clutch to Brake Bracket
18. Flywheel Cover Plug
19. Shifter Tower Cap
20. Shifter Tower Nut
21. Reverse Switch with Connector
22. Starter Cap
23. Clutch Line Clips
24. Clutch Pedal Hose Clamp
25. 2 Starter Bolts
26. 4 Shifter Linkage Bolts/Nuts (hold shifter in place)
27. 2 Center Console Bracket Nuts
28. 3 Shifter Linkage Bolts (in engine bay)
29. 2 Slave Cylinder Bolts
30. 2 Clutch to Brake Bracket Nuts
31. 3 Clutch Pedal Nuts
32. 2 Shifter Tower Bolts
33. 4 Dogbone Bolts
34. Power Steering Line
35. Transmission
that should get you started
