If you saved the old oil, put it in a repurposed plastic jug and let it settle for a few months. Then, slowly pour it into another jug for future use. Future Use would be to add when doing a flush change. As a hobby for the last 15 or so years, I've done maintenance for several of my VW owner friends. I saved all their transmission fluid as well as mine and my son's oil (he has two TDIs) to have for flushing.
For what it is worth, I've been using the Pennzoil Synchromesh in my Jettas for years. I also put it in my Vanagon transmission with the ALH TDI engine. When I built the transmission for my Vanagon, I used "used" oil for break-in and flushing. I changed it out after the first 500 miles, then in 2500 miles, then in 5000 miles and there after every 20k miles with Pennzoil Synchromesh. It has almost 88k miles on it. I'm building a new transmission with improved gear ratios for the ALH engine. Right now, I have about $3000 in the transmission in parts and mods. So, I'll be using "settled" oil for the break-in and flushing before settling on the Pennzoil Synchromesh. There is a fair amount of discussion in the Samba about "settling" used transmission oil for this purpose.
