Whitewater
What is the temp range of the exhaust gas at the turbo inlet? This may drive what kind of epoxy will work.
FYI, this is on the cold side (cold air inlet from air filter) of the turbo not the hot side.What is the temp range of the exhaust gas at the turbo inlet? This may drive what kind of epoxy will work.
The heat cycling probably makes a difference, but I would say it's more due to vibration and aging than anything else.The reason the eyelets break is the heat of the turbo. That’s what I had read elsewhere anyway.
