Lately, on Mk5 BRM cars. I'm finding a crack at the back end of the lower intercooler pipes (3C0145840H, and 3C0145840C depending on the date of mfg) where the hose connected to the turbo connects to the lower intercooler pipe. These are not cracks from accident damage or mechanic abuse. The crack is in the plastic. There is a stainless sleeve inside the plastic pipe and it looks like the plastic is shrinking and cracking. The crack starts right at the end of the pipe and grows in length over time until it reaches past the stainless sleeve and starts leaking boost. It's not the first time I've seen it but now almost every pipe I look at is cracked (but may or may not be leaking yet.) The easy way to find leaks aside from smoke testing, is to look for oil leaking and also if you place your hand up by the pipe near the connection you can feel the lost boost. I usually run the engine up to 2k rpm to make it easy to detect.
In this area of intercooler piping, there are two versions part numbers listed above. The numbers for the tubes going from the front of the lower intercooler pipe to the intercooler are 3C0145832M and 3C0145832D. Referring to the part number last letters ONLY, the C fits the D. The H fits the M.
Anyway, are you guys seeing this happening alot more lately too?
