LavatoryLinksman
A local station down the street still sells it. In some cases can it be better to use the 500ppm fuel vs the 15ppm?
Not in your car...A local station down the street still sells it. In some cases can it be better to use the 500ppm fuel vs the 15ppm?
Have you asked if it is 500 ppm? Maybe they are just slow changing the signing. I would not be surprised if you find out that the guy or gal behind the counter has no idea that 500 ppm is.A local station down the street still sells it. In some cases can it be better to use the 500ppm fuel vs the 15ppm?
I can't see the benefits, maybe it cost's less than the ULSD but still the same here a few kkm away,no thanksA local station down the street still sells it. In some cases can it be better to use the 500ppm fuel vs the 15ppm?
The old "low sulfur" diesel is not for sale ANYWHERE any more - not if you are talking about fuel meant for on-highway use. All on-highway diesel fuel shipped from the refiners has been ULSD for quite some time now. The sign is wrong.
http://en.wikipedia.org/wiki/ULSDWhat do you consider as a ULSD,what's the ppm value?
That is wrong we have 4 stations in Hampton roads, Virginia that sells it. And i have gotten confirmation of that cause they have shown me the sale slips from the tanker trucks that delivered it. IN fact they are all BP stations. So it is still around.
I don't deny that at all. The only reason i know this is cause we filled our military vehicles up there and then i went back to ask them cause i noticed it was labeled as 500ppm and they showed me the delivery slip. I wouldn't use it.500ppm is the new off-road limit (it used to be 5000ppm). If there is any 500ppm fuel still being sold for on-road use, its days are numbered.
... WHEN did you see this??That is wrong we have 4 stations in Hampton roads, Virginia that sells it. And i have gotten confirmation of that cause they have shown me the sale slips from the tanker trucks that delivered it. IN fact they are all BP stations. So it is still around.
Thanks,that's what i thought and wanted to know for sure.We had some problems here so the VW said to my government...if you don't improve your regulations about the fuel we are gonna stop seling the new generation of TDI-s to you,so now (past few years) we have some quality fuel
It may be around but if those stations are sellling LSD for on road, highway use after 12/1/2010, then they are in violation of Federal regulations.That is wrong we have 4 stations in Hampton roads, Virginia that sells it. And i have gotten confirmation of that cause they have shown me the sale slips from the tanker trucks that delivered it. IN fact they are all BP stations. So it is still around.
ULSD in the USA had a phase-in schedule. The final phase-out deadline of the old "low sulfur diesel" has passed. I've forgotten the exact date, but it was some time in mid 2010.
If they are still receiving LSD, and it is not actually ULSD that has been mis-labeled, they are breaking the law.
You are aware that the fuel is likely to be the same under both names.That maybe and frankly i dont care what Bp does cause i refuse to fill up with them i will only fill up with shell..
That maybe but all i know is i had clogged fuel filter with a fill up at a bp. I don't know if there tanks were dirty or if it was a chance of bad delivery but i will not fuel at a bp ever again. I switch to shell at 6000 miles and have been using them since and had no bad fuel since.You are aware that the fuel is likely to be the same under both names.
No problem around here Paul:As a lifelong printer, I am personally offended that people can't be bothered to read their owner's manual.
I need to keep working for about 10 more years, and it won't be easy.
P.
When I was 7, I was told that if you burp and hiccup at the same time You Will Die!!! Doesn't make it true.interesting comments but what about lubricity. I've been told that straight up - the 500ppm is better for one's engine.
OK now we need to back up a step.interesting comments but what about lubricity. I've been told that straight up - the 500ppm is better for one's engine.
myths or misinformation?OK now we need to back up a step.
When the diesel fuel that is now known as "low sulfur diesel" was introduced (1970's?) the refineries responded by using a certain refining process that removed the sulfur compounds. It also turned out that the same refining process also removed certain other compounds associated with lubricity of the fuel. The switch to LSD was followed by a rash of fuel injection system problems and it led to a myth that "sulfur was good" and "low sulfur was bad". Of course, once the problem became apparent, the process was changed at the refineries, and the rash of fuel injection problems went away. But the myth that "sulfur" = "lubrication" persisted.
Please read all the responses. Your 2010 TDI has completely different emission equipment which cannot be removed. It is this stuff that will be damaged. Stuff that was not present on pre-2009 cars.wow paul, thanks for your so enlightened input. what about the tdi's that were running around the world before ULSD - the one's that have run through hundreds of gallons of LSD?
ULSD is recommended for cars built after 2007 (per the sticker at the pump). are you telling me that every jetta that has ever used LSD (anything 2007 and earlier) is damaged and worthless...
in the end these are diesel engines and need something in the tank that can one 1. ignite under compression while 2. being able to 'fit' through the injector and common rail system.
ALL ULSD has lubricity additive - nothing to do with brands. Without additive, it can't meet the legal specifications of most states.Ultra Low Sulphur Diesel is 15 PPM with Lubricity added for Branded fuel and not for Unbranded.
