bta 120
2001 Golf low power
Symptoms wont spool turbo. No or little power, no lights on or codes.
WOT will boost to about 7 to 10 lbs. Then cycle down then up again a couple of times. No vacuum leaks. Mity vac on actuator pulls turbo full travel. Swapped N solenoids, same. Replaced Maf in May this year. Does this sound like plugged intake? Also smokes quite abit when under load and is rough when in neutral just revving.
038 906 012 CP 1.9l R4 EDC G000SG 2839
Group A: '011 Group B: Not Running Group C: Not Running
Engine Speed Boost Boost Charge Pressure
TIME (G28) Specified Actual (N75) Solenoid TIME TIME
Marker STAMP /min mbar mbar % STAMP STAMP
0.01 903 999.6 999.6 24.7
0.31 903 999.6 999.6 24.7
0.62 903 999.6 999.6 24.7
0.93 903 999.6 999.6 24.7
1.24 903 999.6 999.6 24.7
1.56 903 999.6 999.6 24.7
1.87 903 999.6 999.6 24.7
2.18 903 999.6 999.6 24.7
2.49 903 999.6 999.6 24.7
2.83 903 999.6 999.6 24.7
3.18 903 999.6 999.6 24.7
3.52 903 999.6 999.6 24.7
3.88 903 999.6 999.6 24.7
4.25 903 999.6 999.6 24.7
4.61 903 999.6 999.6 24.7
4.95 903 999.6 999.6 24.7
5.29 903 999.6 999.6 24.7
5.61 903 999.6 999.6 24.7
5.92 903 999.6 999.6 24.7
6.23 903 999.6 999.6 24.7
6.55 903 999.6 999.6 24.7
6.85 903 999.6 999.6 24.7
7.17 903 999.6 999.6 24.7
7.48 903 999.6 999.6 24.7
7.79 903 999.6 999.6 24.7
8.1 903 999.6 999.6 24.7
8.41 903 999.6 999.6 24.7
8.75 903 999.6 999.6 24.7
9.11 903 999.6 999.6 24.7
9.46 903 999.6 999.6 24.7
Wednesday 4 October 2017 17:57:01:43035-VCID:60C5A453E0EBB84189-4AB4 VCDS Version: Release 17.1.3 (x64) Data version: 20170320 DS267.7
1.55 903 999.6 999.6 24.7
1.87 945 999.6 999.6 24.7
2.18 1197 999.6 999.6 24.7
2.49 1449 999.6 1009.8 37.5
2.81 1407 999.6 1020 37.5
3.14 1386 999.6 1030.2 37.1
3.5 1260 1009.8 1040.4 36.7
3.86 1218 1020 1040.4 24.7
4.22 1218 1020 1050.6 31.9
4.58 1197 1020 1050.6 25.5
4.94 1239 1030.2 1050.6 34.3
5.3 1344 1060.8 1060.8 37.5
5.65 1449 1081.2 1101.6 37.9
5.97 1470 1132.2 1132.2 37.9
6.29 1659 1203.6 1193.4 40.2
6.6 1848 1295.4 1264.8 43.8
6.92 2037 1723.8 1356.6 33.1
7.24 2205 1948.2 1438.2 24.7
7.55 2394 1948.2 1499.4 24.7
7.86 2520 1948.2 1519.8 28.3
8.18 2625 1948.2 1519.8 28.7
8.48 2730 1948.2 1499.4 27.1
8.8 2793 1948.2 1479 27.5
9.11 2730 1030.2 1448.4 50.6
9.42 2373 1009.8 1295.4 48.6
9.74 2142 1836 1203.6 36.3
10.09 1596 1785 1224 24.7
10.45 1785 1866.6 1264.8 27.9
10.8 1848 1907.4 1315.8 25.5
11.16 1953 1948.2 1366.8 25.5
11.52 2016 1948.2 1417.8 24.7
11.88 2100 1948.2 1458.6 24.7
12.23 2184 1948.2 1489.2 25.1
12.54 2247 1948.2 1519.8 26.3
12.86 2310 1948.2 1540.2 27.9
13.16 2373 1948.2 1540.2 28.3
13.48 2415 1948.2 1540.2 28.7
13.79 2457 1948.2 1530 29.1
14.1 2499 1948.2 1519.8 27.1
14.41 2541 1948.2 1499.4 26.7
14.73 2562 1948.2 1479 24.7
15.04 2583 1948.2 1458.6 25.5
15.36 2604 1948.2 1438.2 25.5
15.67 2625 1948.2 1428 25.9
16 2646 1948.2 1407.6 25.5
16.35 2667 1948.2 1397.4 24.7
16.72 2688 1948.2 1387.2 24.7
17.07 2709 1948.2 1377 24.7
17.44 2709 1948.2 1377 24.7
17.79 2730 1948.2 1377 24.7
18.16 2751 1948.2 1377 24.7
18.51 2751 1948.2 1387.2 24.7
18.85 2688 1020 1387.2 50.6
19.17 2226 999.6 1264.8 48.2
19.49 1953 1948.2 1213.8 25.5
19.79 1806 1876.8 1244.4 25.1
20.11 1827 1897.2 1295.4 24.7
20.42 1869 1917.6 1336.2 24.7
20.73 1911 1938 1377 25.1
21.05 1932 1948.2 1417.8 24.7
21.36 1974 1948.2 1448.4 24.7
21.67 1995 1948.2 1479 25.1
21.98 2037 1948.2 1509.6 24.7
22.29 2058 1948.2 1530 24.7
22.61 2100 1948.2 1550.4 26.3
22.96 2142 1948.2 1570.8 27.5
23.31 2163 1948.2 1581 29.1
23.66 2184 1948.2 1591.2 29.5
24.02 2226 1948.2 1601.4 31.1
24.38 2268 1948.2 1611.6 31.5
24.77 2289 1948.2 1611.6 31.1
25.11 2310 1948.2 1611.6 31.1
25.45 2352 1948.2 1601.4 30.7
25.78 2373 1948.2 1591.2 30.7
26.1 2394 1948.2 1591.2 29.5
26.43 2394 1948.2 1581 28.7
26.74 2415 1948.2 1560.6 28.3
27.05 2436 1948.2 1550.4 27.5
27.36 2457 1948.2 1550.4 26.3
27.67 2478 1948.2 1540.2 25.5
27.99 2478 1948.2 1519.8 24.7
28.3 2499 1948.2 1509.6 24.7
28.61 2520 1948.2 1499.4 24.7
28.92 2520 1948.2 1489.2 24.7
29.24 2520 1948.2 1479 25.5
29.55 2541 1948.2 1458.6 26.3
29.91 2541 1948.2 1448.4 25.1
30.27 2562 1948.2 1448.4 25.1
30.63 2562 1672.8 1438.2 25.5
30.99 2268 1009.8 1336.2 48.2
31.35 2058 1948.2 1213.8 47.8
31.71 1848 1897.2 1244.4 24.7
32.04 1848 1897.2 1295.4 25.1
32.35 1869 1907.4 1346.4 24.7
32.66 1869 1917.6 1387.2 24.7
32.98 1890 1927.8 1428 24.7
33.29 1890 1938 1448.4 25.1
33.6 1911 1948.2 1479 24.7
33.91 1932 1948.2 1509.6 24.7
34.23 1953 1948.2 1540.2 25.5
34.53 1953 1948.2 1550.4 25.5
34.85 1974 1948.2 1570.8 27.5
35.16 1995 1948.2 1591.2 27.1
35.47 2016 1948.2 1591.2 29.9
35.79 2037 1948.2 1601.4 28.3
36.11 2037 1948.2 1611.6 29.5
36.47 2058 1948.2 1621.8 30.3
36.82 2079 1948.2 1632 29.1
37.16 2079 1907.4 1632 29.5
37.52 2079 1091.4 1611.6 84.5
37.88 2079 1030.2 1295.4 44.6
38.23 2079 1060.8 1183.2 45.4
38.56 2079 1948.2 1162.8 24.7
38.87 2100 1948.2 1213.8 24.7
39.19 2100 1948.2 1295.4 24.7
39.5 2121 1948.2 1356.6 24.7
39.81 2121 1744.2 1407.6 27.9
40.12 2058 999.6 1438.2 43.8
40.43 2121 999.6 1305.6 44.6
40.74 2100 999.6 1203.6 43.8
41.06 2079 999.6 1142.4 43.8
41.37 1701 999.6 1111.8 40.2
41.68 1281 999.6 1091.4 38.3
41.99 1092 999.6 1071 24.7
42.31 1092 999.6 1050.6 24.7
42.63 1071 999.6 1040.4 24.7
42.98 1050 999.6 1030.2 24.7
43.34 1029 999.6 1020 24.7
43.7 987 999.6 1020 24.7
44.06 945 999.6 1009.8 24.7
44.42 924 999.6 1009.8 24.7
44.77 903 999.6 1009.8 24.7
45.1 924 999.6 1009.8 24.7
45.42 924 999.6 1009.8 24.7
45.74 924 999.6 1009.8 24.7
46.05 903 999.6 1009.8 24.7
46.37 903 999.6 999.6 24.7
46.67 903 999.6 999.6 24.7
46.98 903 999.6 1009.8 24.7
47.3 903 999.6 999.6 24.7
47.61 903 999.6 999.6 24.7
47.92 903 999.6 999.6 24.7
48.24 903 999.6 999.6 24.7
48.55 903 999.6 999.6 24.7
48.87 903 999.6 999.6 24.7
49.23 903 999.6 999.6 24.7
49.58 903 999.6 999.6 24.7
49.93 903 999.6 999.6 24.7
50.28 903 999.6 999.6 24.7
50.63 903 999.6 999.6 24.7
50.99 903 999.6 999.6 24.7
51.34 903 999.6 999.6 24.7
51.66 903 999.6 999.6 24.7
51.98 903 999.6 999.6 24.7
