kw1281test: A Free VDS-Pro / VagTacho Alternative
gmenounos
Watertown, MA, USA
'99.5 Golf GLS, '01 Jetta GLX Wagon (TDI conversion), Non-TDI: '23 Tesla Model 3 AWD
Does this work on the Audi A3 8p? Have a car where we want to enable needle sweep, it’s possible through VCDS on next years model, but on this it isn’t (as far as I can see). You can go to block 39 and see options to change from 100 to 101, but it won’t let you save due to it not being an S3. Have read about changing bits in the eeprom, so wondered if KW1281 reads & writes in the same manner for this cluster.
Nope, kw1281test only works with cars that use K-line diagnostics and the A3 8P uses CAN bus: https://www.ross-tech.com/vcds/canbus.php
Oloxx03
Barcelona, Spain
Seat Leon 1M
Hi! I want to activate the remote windows feature in a Seat Ibiza 6L 1.4TDI, how can I do it? The ID of the CCM is 6Q0 959 433 E, thanks!
gmenounos
Watertown, MA, USA
Does anybody know why I would get unsupported Cluster?
I'm in the US so I don't have easy access to Seat and Skoda clusters. I've bought a few foreign clusters on eBay and that's helped me add support for those, but yours is one that I don't have. There's a "Sponsor this project" link on the kw1281test project page. Donations help me afford more clusters. I've been able to add support for all the ones I own (except for one pesky Audi TT cluster), but there's no way to tell whether I can add support for a cluster until I have at least one.
fuhrmann07
kelowna, bc
2004 golf
For the EDC16's in the BEW's any good solutions to get the skc out of a ecu that I want to swap into my car? (tuned)
Looked at vag tacho but it appears to run on older operating systems which is a pain the oldest i have is windows 10..
Only plan on doing this once...
Thanks for the effort here, was able to pull my skc out of the cluster with almost no issues.
Thx
Limitedblack
London
Having small issue on a CCM I am trying to work on (on bench). I can only read the eeprom after I have read the cluster. So if I just type in the correct argument it just comes back with an error from module 46. If I request a read from module 17, then straight after module 46 it reads ok. I am aware of different baud rates of both units. Is this a known issue?
Error seems to always be here:
Args: com2 9600 46 readeeprom 4361
OSVersion: Microsoft Windows NT 10.0.19045.0
.NET Version: 8.0.0
Culture: en-GB
Opening serial port com2
Sending wakeup message
Wakeup duration: 2 seconds
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Protocol is KW 1281 (8N1)
Caught: System.InvalidOperationException Received block end $0F but expected $03
Unhandled exception: System.InvalidOperationException: Received block end $0F but expected $03
at BitFab.KW1281Test.KW1281Dialog.ReceiveBlock() in C:\Users\gmeno\src\kw1281test\KW1281Dialog.cs:line 392
at BitFab.KW1281Test.KW1281Dialog.ReceiveBlocks() in C:\Users\gmeno\src\kw1281test\KW1281Dialog.cs:line 351
at BitFab.KW1281Test.KW1281Dialog.Connect() in C:\Users\gmeno\src\kw1281test\KW1281Dialog.cs:line 91
at BitFab.KW1281Test.Tester.Kwp1281Wakeup(Boolean ) in C:\Users\gmeno\src\kw1281test\Tester.cs:line 39
at BitFab.KW1281Test.Program.Run(String[]) in C:\Users\gmeno\src\kw1281test\Program.cs:line 266
at BitFab.KW1281Test.Program.Main(String[]) in C:\Users\gmeno\src\kw1281test\Program.cs:line 29
Version 0.86-beta (https://github.com/gmenounos/kw1281test/releases)
Lancaster, PA
2002 ALH TDI Golf
First off, thanks for all your amazing work on this! It’s been fun to play around with, and enable things (auto unlock on key removal) that I’ve been wanting forever! The reason I found this is I was looking for a solution for new keys as I just had mine break. I now have 3 new cut keys with fobs. One of the fobs is the original board, swapped to a new housing, along with the original RFID, the other 2 are cut virgin keys. I’ve successfully got all 3 adapted to the immobilizer, but I’m having trouble with the fobs.
The original fob works as normal, I’ve tried the method of turning the ignition to on, locking the door with the new fob, and holding the buttons, and then unlocking and removing the key from the ignition. That works for 1 fob, but the second I do the second fob, the first one stops working, and it just cycles that way. Any help??
I also tried setting the CCM Adaption to 0 0 (and then 1 3) but that didn’t do anything.
Lancaster, PA
2002 ALH TDI Golf
After lots more testing. Here’s where I’m stuck. AdaptationSave returns NAK. Reading and testing is fine, but it won’t save….
Code:
[bellabuckwalter@Bella-Buckwalters-MacBook-ProDesktop%./kw1281test12345678960046AdaptationSave000
KW1281Test: Yesterday's diagnostics...Today.
Version 0.93.0-beta (https://github.com/gmenounos/kw1281test/releases)
Args: 12345678 9600 46 AdaptationSave 00 0
OSVersion: Unix 10.15.7
.NET Version: 8.0.0
Culture: en-US
Opening FTDI serial port 12345678
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
ECU: 1C0959799C 1Q Komfortgerat HLO 0003
Software Coding 00258, Workshop Code: 00001
Sending AdaptationRead block
Received a NAK.
Sending EndCommunication block
gmenounos
Watertown, MA, USA
Code:
.NET Version: 8.0.0
Culture: en-US
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Received a NAK.
See if you get any better results with v0.95-beta: https://github.com/gmenounos/kw1281test/releases/tag/v0.95-beta
Limitedblack
London
Does anyone know if a 3B0920949C (eeprom V05), can be programmed to work in a Skoda Octavia (was 1U0920811A). Not sure if it is codes or different hardware on Passat clutter as early VDO. I’m guessing 1J0 bin should work, but can not find a sump of eeprom V07
gmenounos
Watertown, MA, USA
Hi All
I'm after some advice, injector pump failure on my car. I've replaced it with a new one that now needs coding to car.
I came across this thread and hoping it would help me out. I ran the program as described and it returned the following.
Version 0.92-beta (https://github.com/gmenounos/kw1281test/releases)
Args: COM1 10400 17 GetSKC
OSVersion: Microsoft Windows NT 10.0.19042.0
.NET Version: 8.0.0
Culture: en-GB
Opening serial port COM1
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
ECU: 4B0920981J KOMBI+WEGFAHRS. VDO D15
Software Coding 04460, Workshop Code: 00000
Sending ReadIdent block
Sending Custom "Read Software Version" blocks
Sending Custom "Unlock Additional Commands" block
Cluster did not return software version.
Unknown cluster software version. EEPROM access will likely fail.
Sending Custom "Need Seed/Key?" block
Sending Custom "Seed request" block
Failed to unlock cluster.
Saving EEPROM dump to WAUZZZ4B85N015236_____AUZ7Z0D2642100_$0090_eeprom.bin
Sending ReadEeprom block (Address: $0090, Count: $10)
Sending ReadEeprom block (Address: $00A0, Count: $10)
Sending ReadEeprom block (Address: $00B0, Count: $10)
Sending ReadEeprom block (Address: $00C0, Count: $10)
Sending ReadEeprom block (Address: $00D0, Count: $10)
Sending ReadEeprom block (Address: $00E0, Count: $10)
Sending ReadEeprom block (Address: $00F0, Count: $10)
Sending ReadEeprom block (Address: $0100, Count: $0C)
*** Warning: Some bytes could not be read and were replaced with 0 ***
Saved EEPROM dump to WAUZZZ4B85N015236_____AUZ7Z0D2642100_$0090_eeprom.bin
GetSkc: Unable to find Immobilizer ID in cluster dump.
Unable to determine SKC.
any help would be much appreciated.
I've tried contacting auto locksmiths but trying to get one to come out to have a look is near on impossible!
thanks in advance
Pete
New release: https://github.com/gmenounos/kw1281test/releases/tag/v0.96-beta
Can you download that and see if the GetSKC command works any better with your cluster?
midgetpdx
Tucson AZ USA
GTI mk5
Hi
I have a 2007 GTI mk5 (with VDO cluster, I think)
I installed the RossTech USB with VCP drivers and get the following timeout message:
Args: com4 10400 17 GetSKC
.NET Version: 8.0.0
Culture: en-US
Opening serial port com4
Reading sync byte
The operation has timed out.
Retrying wakeup message...
Reading sync byte
Reading sync byte
Caught: System.InvalidOperationException Controller did not wake up.
Unhandled exception: System.InvalidOperationException: Controller did not wake up.
at BitFab.KW1281Test.KwpCommon.WakeUp(Byte, Boolean) in /Users/gmenounos/src/kw1281test/KwpCommon.cs:line 62
at BitFab.KW1281Test.Tester.Kwp1281Wakeup(Boolean ) in /Users/gmenounos/src/kw1281test/Tester.cs:line 33
at BitFab.KW1281Test.Tester.GetSkc() in /Users/gmenounos/src/kw1281test/Tester.cs:line 509
at BitFab.KW1281Test.Program.Run(String[]) in /Users/gmenounos/src/kw1281test/Program.cs:line 275
at BitFab.KW1281Test.Program.Main(String[]) in /Users/gmenounos/src/kw1281test/Program.cs:line 31
where should I look next?
gmenounos
Watertown, MA, USA
kw1281test won't work with your car because it doesn't use a K-line for diagnostics. From the first page of this discussion:
Q: Will it work with my car?
A: kw1281test works with many VW group cars that use the K-Line for diagnostics. It's been most heavily tested on the VW MKIV Golf/Jetta/Beetle. It will not work on cars that use CAN bus diagnostics such as those listed here.
ts54
AMS
Hi all,
First of all thanks to everybody contributing to this powerful kw1281test tool! Especially @gmenounos for creating and updating it. It's amazing to read all the information in this topic for different clusters.
I have a problem of my own trying to get the SKC for a cluster from my sisters Audi TT. Her old cluster is broken and I ordered a replacement cluster with the exact part number as the original. I did this trick before with a Passat B5 cluster (15 years ago :)) and I was hoping to do the same now. Unfortunately I spent the last 2 days trying to get the SKC without any success...
The details of the cluster are:
Part number: 8N1 919 880 E
Make: Magneti Marelli M73 D26
Year: 03 2000 (March 2000)
I tried VAG Eeprom Programmer 1.19, VAG K + CAN Commander 1.4 and 2.5 and kw1281test.
VAG Eeprom Programmer: Connects successfully, reads the ECU details (name, make and version) and returns error "unknown software version".
VAG K + CAN Commander 1.4 and 2.5: Connects successfully. I can make 2 dumps using mode 'Shadow 3 (TT)' and mode 'Direct'. Both produce a .bin file but when I (try) to read the contents and do a compare with dumps from other clusters I can't figure out the SKC. I attached the .bin file from the 'Direct' command as attachment.
kw1281test: Connects successfully but can't get SKC with GetSKC command. In this topic I found 2 commands to try for a Marelli cluster. I tried 'DumpMarelliMem 14336 2048' and 'DumpMarelliMem 3072 1024'. Only the first command works. The second command throws a timeout during the 'receiving memory dump' step, and reboots the cluster. I attached the .bin file from the first command as well.
I looked at the source code from kw1281test and because I'm a programmer I can read and understand what is happening. What I don't know is the specific knowledge about the kw1281 protocol and the specific implementations for the clusters. I'm willing to try and change something but I don't know what.
Can anybody point me in the right direction or does anybody know another option to get the SKC from this cluster? Perhaps another piece of software (with another cable).
Dump files from cluster: https://we.tl/t-igspncWf7t
gmenounos
Watertown, MA, USA
Is this car Immo2 or Immo3? If it's Immo2 then the SKC isn't in the cluster - only in the ECU.
ts54
AMS
The car is a European Audi TT from 2000. The car is Immo2 and the cluster as well.
I double checked with the instructions from Ross Tech (VCDS). https://www.ross-tech.com/vag-com/cars/Immo2-cluster-swapping.html
I was thinking when reading all the info, with Immo2 the SKC is saved in the dashboard and with Immo3 the SKC is saved in the dashboard and the ECU.
Edit: I currently have the new dashboard in a 'bench setup'. It's on my desk hooked with wires to 12v and a cable for the k-line both connected to a OBD cable. All communications seem to be working fine, also with VCDS. Could be useful to know..
gmenounos
Watertown, MA, USA
Is the odometer about 230048km? If so, try 02251 for the SKC and post whether it works or not.
ts54
AMS
The odometer is 230072 KM.
I just arrived at work, will give it a try when I get home! If it works I'm really curious how you found it.. Thank you so far for your time 😄
ts54
AMS
I just tried to log in using VCDS and this code is working! After I put in the code the key-immobilizer led stopt blinking on the dashboard. Assuming I can program the existing keys now. Thank you so much!:D
I'm really curious how you got this information out of my dump files. Is it possible, for me perhaps, to implement this in kw1281test?
Also I would like to know if I can change the odometer, to match the real mileage of the car. If that's too risky I will not do it since the milage is only off by 6K so I can live with that...
Again thanks for your support. You're a lifesaver!
gmenounos
Watertown, MA, USA
There's some software floating around called NYO4 that knows where the SKC and odometer live in a huge variety of clusters. You won't be able to use kw1281test to update your odometer even if you knew where it was in the dump because it doesn't support writing to Marelli (i.e. TT/Beetle) clusters.
gmenounos
Watertown, MA, USA
Shiboxtdi
Indiana
2003 VW JETTA ALH TDI (SOLD)
I’ve been looking for a VCDS, I know Ross tech sells them but I can’t see paying 200$ for it (call me a cheap a** all you want) I seen them on Ali express and I’ve seen the threads about them have a “virus”. And I’ve also seen the obd eleven, I would like that because I wouldn’t need a laptop and I could just use my phone for it, but you have then pay for the description and in my time of reading about it all I can gather is you pretty much have to pay everytime you click on something😂. I may be wrong but that’s how I’ve took it. And I’ve also seen the VAG KKL, which I have access to a laptop or computer whatever you want too call it. My questions are…
has anyone bought the hex v2 off of Ali express and used it and got any viruses from it and or does it work fine like if you were to buy it off of Ross tech.
What is the difference between the hex v2 and the VAG KKL, do they do the same thing?
even with my young age (16😂) I’m no computer scientist by no means and quite frankly I don’t even know how too download the software for the VCDS
Sorry for any misunderstandings this is way out of my brains reach and I can’t even wrap my head around how too use any of this stuff
Thank you in advance
Mozambiquer
Versailles Missouri
The knockoff ones don't work the same as the real vcds. They only work with cracked old versions of vcds or vcds-lite. The real vcds they do free updates and have support.
If you have an mk4, you can simply get a kkl cable and run vcds-lite, which is free unless you want to do adaptations then they charge a $99 registration fee. That only works for the older k-line cars, so mk4 and B5 passat at the latest.
I would not get the knockoff ones with a disk. For one, they are illegal pirated devices, and the other, they often do have viruses and are not able to update at all.
You also can only use the software that comes with them, as the real vcds software does not work with them.
Shiboxtdi
Indiana
I have a mk4, would I be able too use the vcds lite and still do coding like deleting immobilizer or check fuel pressure, code key to the car etc
P2B
Toronto & Muskoka, Canada
There are two ways to get VCDS - buy it or steal it.
Please don't ask for advice on the latter here.
VCDS Lite is read only, you cannot make changes with it.
Mozambiquer
Versailles Missouri
You will want the real full vcds for any coding. You cannot use vcds to delete the immobilizer, but can use it to program the immobilizer after pulling the skc with this software.
Sometimes you can get the old unlimited vin ones on eBay for cheaper, just make sure its a real one, or itll be a paperweight that doesn't even hold paper down well...
