gmenounos
- Joined
- Jun 26, 2003
- Location
- Watertown, MA, USA
- TDI
- '99.5 Golf GLS, '01 Jetta GLX Wagon (TDI conversion), Non-TDI: '23 Tesla Model 3 AWD
2022-09-20
When I started this thread, I didn't realize that it would grow so large. While reading through the 1000+ posts might be interesting, it's not going to get you your SKC or mod your CCM very quickly. To save you some time, I'll include some basic info here before the historical stuff starts...
Q: What is kw1281test?
A: It's a program I wrote in 2020 to helpTDI VW VAG owners retrieve their vehicle's SKC and program their CCMs using a generic KKL cable that you can probably pick up for $20 or so. It runs on Windows 10/11, macOS and Linux. It's open source so you can copy it, modify it or just read through the source code to understand how it works. But it's a command line program and only works with cars that support diagnostics via the K-Line. For VWs, this means only MKIV cars are supported.
Q: Where can I get it?
A: The latest version should always be here: https://github.com/gmenounos/kw1281test/releases (look under Assets) A list of commands is here: https://github.com/gmenounos/kw1281test#readme
Q: Will it work with my car?
A: kw1281test works with many VW group cars that use the K-Line for diagnostics. It's been most heavily tested on the VW MKIV Golf/Jetta/Beetle. It will not work on cars that use CAN bus diagnostics such as those listed here.
Q: What do I need to buy?
A: You need a KKL cable like this one. Drivers for that cable can be found here. You can also use older VCDS cables if they support VCP mode.
Q: Why do I need my SKC?
A: You'll need it if you want to match a new key to your car. You'll also need it if you ever need to install a replacement cluster or ECU.
Q: Can't I just buy a cheap VagTacho cable from eBay?
A: Most (all?) of the copies of VagTacho and similar tools on eBay are cracked copies of much more expensive commercial products. Some of the installation CDs contain viruses and the cables can be flaky and usually only work with that one program.
Q: Just tell me how to get my SKC!
A: If you're running Windows 10/11 and have a VDO cluster: Download kw1281test, unzip it to some folder on your computer, install the driver for your cable and note what COM port it's using in Device Manager, open up a command prompt, CD to the folder containing kw1281test.exe and, assuming your cable is using COM1, type:
Q: Ok, I got my SKC. What else can it do?
A: It can read/write to your CCM's EEPROM, allowing you to enable the "Roll windows up/down with key fob" feature. It can retrieve the SAFE code of some VW radios, saving you a trip to the dealer. It can read/clear fault codes, do adaptation, read measuring blocks (including Basic Setting), set module coding and run output tests.
Q: It didn't work. How can I get help?
A: You can post a new message in this thread. Ideally do some reading/searching first in case you're having the same problem that someone else did. If you think you found a bug, you can open an issue here: https://github.com/gmenounos/kw1281test/issues
Q: Why's it called "kw1281test"?
A: It talks to your car mostly using VW's proprietary KW1281 protocol.
Q: Why is it a command line program?
A: That was easiest for me. I have a day job so I only have limited time for hobby stuff like this. It also made it relatively easy to get it running on macOS and Linux.
Q: Why did you write it in C#?
A: That's the programming language I know best. Recent versions also happen to run nicely on macOS and Linux.
2020-08-06
So I've been a happy VCDS user since buying my Golf in 2003 (it had 65000 miles on it so it conveniently needed an immediate timing belt replacement, hence needing VCDS - though it was named VAG-COM way back then).
However there are things that VCDS doesn't do, such as pulling the SKC from an instrument cluster, changing the odometer of a used cluster, reading/writing bytes in the CCM, retrieving a used radio's Safe code, etc.
Since I have a part-time "business" (really more like a hobby at this point) involving fixing up MKIV instrument clusters and reselling them, VagTacho or similar (VAG Commander, VAGdashCOM, VAG EEPROM Programmer, etc.) is a necessity. The problem is that legitimate copies of these tools cost hundreds of dollars and require special dedicated cables. You can find cheap pirated copies of many of these, but some still require special cables and you never know what malware might be lurking on the plain white mini-CDs that the software comes on. (I eventually did by a real copy of VAGdashCOM after having lots of trouble with flaky eBay VagTacho cables). And it's not only me that needs these tools. If I sell a cluster to someone, they need to know their SKC in order to install it. If I set the odometer to 0, they can adjust it to the correct value with VCDS, but no VagTacho, no SKC, no start.
I've also always wanted to use VDS-PRO to enable the "Roll windows up/down with key fob" CCM feature and other options, but it only runs on DOS and hasn't been maintained in many years. I've had lots of trouble getting it to run at all on newer computers.
Fast forward to a couple of months ago: I bumped into Mike Naberezny's GitHub page: https://github.com/mnaberez/vwradio
Mike has done the amazing job of reverse engineering 8 (so far) VW/Seat/Skoda radios and has found various hidden commands and discovered ways to retrieve the Safe code from most of them via the K-Line and some open-source hardware/software that he created. He's made all the info available for free. The only downside is that his software runs on a custom circuit board and that's a barrier to most people.
So that got me thinking that maybe I could do something similar in software that runs on a PC and a generic cable. I was able to find a good bit of info about VW's proprietary KW1281 K-Line protocol here and learned some more by reading Mike's code. I bought a Saleae logic analyzer and was able to use it to spy on the K-Line while using various cluster tools and VDS-PRO in order to figure out which KW1281 commands were being used to read/write the EEPROM, reboot the cluster, etc.
I was then able to write a program that could wake up a module and send simple commands over the K-Line. Eventually I got it to the point where it could read/write bytes in the CCM EEPROM like VDS-PRO and retrieve the Safe code from a VW Premium V radio like Mike's tool. The big thing missing was the ability to read/write the cluster EEPROM. That required performing a successful challenge/response with the cluster. The commercial tools all know how to do that but it's not documented anywhere that I could find. Finally with some pointers from Mike, I was able to partially disassemble the cluster ROM in order to find how the challenge/response works and am now able to dump the entire cluster EEPROM to a file for editing. I only just got this working yesterday so I haven't tried writing the EEPROM back yet but that should be pretty straightforward to get working.
I uploaded all the source code to GitHub: https://github.com/gmenounos/kw1281test
You can download the source code and build it yourself or there's a .zip file containing a precompiled version that runs on Windows 10 here:
https://github.com/gmenounos/kw1281test/releases/
Currently it just runs from the command line but that might be just fine for now. It requires a dumb KKL cable, basically something with an OBD connector on one end and that looks like a serial port to the PC. I've successfully used a KKL cable I bought 7 years ago that connects to an actual serial port on my really old laptop. I've also used a genuine VCDS cable configured to run in VCP (Virtual COM Port mode). I've only run it on an old Dell laptop that runs 32-bit Windows 10. It should work fine on 64-bit Windows 10 but I haven't actually tried that yet. It's written in C# for .NET Core, which is cross-platform, so it might also run on Macs and Linux but I haven't tried either. You're welcome to give it a shot and let me know.
To run the tool, you have to know what COM port your cable is using, what baud rate to use, what controller address to connect to and what command you want to send. A fancier tool like VCDS will automatically detect the baud rate of the controller but I was too lazy to figure out how to do that so you must know the baud rate. I can tell you that the cluster uses 10400.
Here's the tool reading a cluster's software version:
Maybe not too exciting, but here's it dumping the cluster EEPROM to a file:
Here's a full list of commands. You'll see that same info if you just run the program and don't specify any parameters.
So if this sounds useful, please give it a try and let me know if it works for you. I'm interested in hearing what cables it works with, which controllers it can talk to and which is has trouble with, bug reports and suggestions for new features.
.\kw1281test.exe COM1 10400 17 GetSKC
2020-08-06
Code:
PS C:\> .\kw1281test.exe com4 10400 17 ReadSoftwareVersion
Opening serial port com4
Sending wakeup message
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Protocol is KW 1281 (8N1)
ECU: 3B7920946E KOMBI+WEGFAHRSP VDO V095
Sending Custom "Unlock Additional Commands" block
Sending Custom "Read Software Version" blocks
00: VWK501MH $10 $01
01: $81 $19
02: $18 $08 $01 $0B $1C $09
03: VW/Sk MH Serie/Flash
Sending EndCommunication block
Code:
PS C:\> .\kw1281test.exe com4 10400 17 DumpEeprom 0 2048
Reading sync byte
Keyword Lsb $01
Keyword Msb $8A
Sending ReadIdent block
Sending Custom "Unlock partial EEPROM read" block
Sending Custom "Are you unlocked?" block
Sending Custom "Seed request" block
Block: 7A 42 2A DE 80 28 6F 45 01 00
Sending Custom "Key response" block
Sending ReadEeprom block (Address: $0000, Count: $10)
Received "Read EEPROM Response" block: 09 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Sending ReadEeprom block (Address: $07F0, Count: $10)
Received "Read EEPROM Response" block: FF 4C 00 00 00 00 00 FF FF FF 08 0E 08 0E 08 0E
Saving EEPROM dump to WVWUK63B33P247312_____VWZ7Z0B6069175_$0000_eeprom.bin
Code:
Usage: KW1281Test PORT BAUD ADDRESS COMMAND [args]
PORT = COM1|COM2|etc.
BAUD = 10400|9600|etc.
ADDRESS = The controller address, e.g. 17 (cluster), 46 (CCM), 56 (radio)
COMMAND = ReadIdent
ReadSoftwareVersion
ReadEeprom ADDRESS
ADDRESS = Address in decimal (e.g. 4361) or hex (e.g. $1109)
WriteEeprom ADDRESS VALUE
VALUE = Value in decimal (e.g. 138) or hex (e.g. $8A)
DumpEeprom START LENGTH
START = Start address in decimal (e.g. 0) or hex (e.g. $0)
LENGTH = Number of bytes in decimal (e.g. 2048) or hex (e.g. $800)
DumpRom START LENGTH
START = Start address in decimal (e.g. 8192) or hex (e.g. $2000)
LENGTH = Number of bytes in decimal (e.g. 65536) or hex (e.g. $10000)
MapEeprom
Reset
DelcoVWPremium5SafeCode
