Ran it, then power cycled my ignition. Freaked out because I no longer saw the IMMO light light up. Started my beetle and it started and immediately died. Then totally freaked out, power cycled again, still no immo light. I then hoped that I could recover the Immo2 with VCDS or the the VagTacho cable I rented but a moment later I heard a whirr, the cluster rebooted itself and then I saw the immo light light up. I power cycled the ignition, the immo light turned on, then off, and I could start my car fine.
However the trip meter reset to 0.0, and the airbag light is now on, just like when I used VagTacho to pull the PIN. Whew!
I hooked up my VCDS cable, cleared the airbag code, and for good measure I logged into the cluster using the PIN I extracted the day before and I got in! Double sigh of relief! Exited, cycled the ignition power, and now have a solid IMMO light. Darn! I remember having this problem yesterday too when I wanted to verify how many keys were memorized. Seems just logging into the cluster, or seeing how many keys are available causes one to have to repeat the pairing process.
So back to VCDS, re-paired my 3 keys, airbag light is off, everything seems back to normal, and my adrenaline is tapering off.
I have a bin file for you but need to figure out how to send it to you.
