glow plugs are light light bulbs. change the ones that go bad as they go bad.
in your house, you dont change every light bulb at the same time when one goes bad right? same deal.
Don't know about that.
Everytime one goes out and you replace it, you have to get the Check Engine Light reset with a scan tool. The light does not go out simply by replacing the faulty plug.
If you own the scan tool yourself it is not that big of a deal.
And, for the average owner, they may have to go to a repair facility to get it done for a minimum service/ inspection charge which could be a lot depending on where you go. If the plugs have been in there a long time, get them all changed so that you will know where they stand.
The glow plug fault code on the 2006 New Beetle will point directly to the faulty glow plug...or circuit. Glow plug fault codes generally can not tell if it is due to the glow plug or the harness connection to the plug. ECU just knows that the circuit resistance is not what it should be.
Also, do not rely upon Autozone, etc... to provide the correct glow plugs.
Many chain store will prescribe the same glow plug for vehicles from 1996 to 2006 and it ain't so. Your car has glow plugs that work at a different voltage than the pre-2004 cars and are also software update dependent. You will have to know which software is in your engine computer to get it right. Getting that wrong will produce hard starts in cold weather or over voltage to the wrong plugs.
The proper plugs for your car are not the cheapest out there.
The lastest revision for your car has this VW part number:
N10591609
They are made by NGK.
It is possible that these plugs came in your car from the factory with the latest software to match. Maybe someone else here can verify that.
The ones for a 2006 Jetta TDI are not the same so make sure that you go to a reliable source when the time comes.
One such source is this:
https://www.idparts.com/glow-plug-7v-oem-ngk-ceramic-a4-bewbhw-p-2178.html
BUT...you need to establish which engine computer software is in the car first.
While being in Texas will minimize your starting problems due to glow plugs you would run into problems if you go to Montana on the colder days. Having the right ones in there will help you to forget about them. They will do the job as necessity dictates.
