Screamingdeal
Hey yall,
New to me 01 golf tdi alh. Bought it, drove fine, get on freeway, overboost issue. Not too sure where to start, still learning. stuck veins? Maybe EGR? No coms, Fuses, bad grounding? Any input is appreciated.
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 316950km-196943miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 CP
Component: 1,9l R4 EDC G100SG 2839
Coding: 00002
Shop #: WSC 00001
VCID: 6099A9701355625BEF3-4B3C
2 Faults Found:
16618 - Boost Pressure Regulation
P0234 - 35-10 - Limit Exceeded (Overboost Condition) - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
Readiness: 1 1 0 0 0
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 08 AIRBAG VW6 0202 0004
Coding: 12344
Shop #: WSC 00001
VCID: 3A2D3B18D549588B817-4B3C
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 905 M
Component: A4-KOMBIINSTR. VDO V01
Coding: 07232
Shop #: WSC 29036
VCID: 313F1C34083F9BD330D-5184
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2831420
IMMO-IDENTNR: VWZ7Z0Y2831420
3 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module
01315 - Transmission Control Module
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00007
Shop #: WSC 23071
VCID: 70B9D930C3B5D2DB7F3-5184
3 Faults Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 60 Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00001
VCID: 06559FE8D131EC6BB5F-4B1E
Subsystem 1 - Part No: 1J1959801C
Component: 60 T��euerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 60 T��euerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 60 T��euerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 60 T��euerger. HR0002r
4 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
01179 - Incorrect Key Programming
35-00 - -
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
00913 - Window Regulator Switch; Front Right Driver (E81)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 B
Component: Radio DE2 0003
Coding: 04041
Shop #: WSC 05311
VCID: 1E65D78869A114AB9DF-51F2
No fault code found.
End----(Elapsed Time: 05:17, VBatt start/end: 11.6V/11.5V. VIgn 11.4V)-----
76
Coding: 00002
Shop #: WSC 00001
2 Faults Found:
P1570 - 35-00 -
Coding: 12344
Shop #: WSC 00001
1 Fault Found:
Coding: 07232
Shop #: WSC 29036
3 Faults Found:
Coding: 00007
Shop #: WSC 23071
3 Faults Found:
Coding: 04097
Shop #: WSC 00001
4 Faults Found:
35-00 - -
Coding: 04041
Shop #: WSC 05311
