Just installed VCDS....results
Screamingdeal
Mac
1980 Rabbit td, 2014 Golf Sportwagen tdi, 01 golf tdi
Hey yall,
New to me 01 golf tdi alh. Bought it, drove fine, get on freeway, overboost issue. Not too sure where to start, still learning. stuck veins? Maybe EGR? No coms, Fuses, bad grounding? Any input is appreciated.
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 316950km-196943miles
Address 01: Engine Labels: 038-906-012-AGR.clb
Part No: 038 906 012 CP
Component: 1,9l R4 EDC G100SG 2839
Coding: 00002
Shop #: WSC 00001
VCID: 6099A9701355625BEF3-4B3C
2 Faults Found:
16618 - Boost Pressure Regulation
P0234 - 35-10 - Limit Exceeded (Overboost Condition) - Intermittent
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
Readiness: 1 1 0 0 0
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 F
Component: 08 AIRBAG VW6 0202 0004
Coding: 12344
Shop #: WSC 00001
VCID: 3A2D3B18D549588B817-4B3C
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 905 M
Component: A4-KOMBIINSTR. VDO V01
Coding: 07232
Shop #: WSC 29036
VCID: 313F1C34083F9BD330D-5184
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2831420
IMMO-IDENTNR: VWZ7Z0Y2831420
3 Faults Found:
01314 - Engine Control Module
49-10 - No Communications - Intermittent
01316 - ABS Control Module
01315 - Transmission Control Module
49-00 - No Communications
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway K<->CAN 0001
Coding: 00007
Shop #: WSC 23071
VCID: 70B9D930C3B5D2DB7F3-5184
3 Faults Found:
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 60 Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 00001
VCID: 06559FE8D131EC6BB5F-4B1E
Subsystem 1 - Part No: 1J1959801C
Component: 60 T��euerger. FS0002r
Subsystem 2 - Part No: 1J1959802D
Component: 60 T��euerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 60 T��euerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 60 T��euerger. HR0002r
4 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
01179 - Incorrect Key Programming
35-00 - -
00912 - Window Regulator Switch; Front Left (E40)
27-10 - Implausible Signal - Intermittent
00913 - Window Regulator Switch; Front Right Driver (E81)
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 B
Component: Radio DE2 0003
Coding: 04041
Shop #: WSC 05311
VCID: 1E65D78869A114AB9DF-51F2
No fault code found.
End----(Elapsed Time: 05:17, VBatt start/end: 11.6V/11.5V. VIgn 11.4V)-----
Tdijarhead
Lawrenceville PA
It looks like the battery ran low causing several of those codes. Since you have them recorded clear them and see what comes back.
The over boost code will likely and the door lock codes. Is your airbag light on?
There are write ups on fixing both over boost and door lock issues on this site.
If your air bag light is on you should be able to clear it and it will stay out since it appears to be a low voltage code. If the light is not on don’t worry about it.
Screamingdeal
Mac
Thanks for the reply. No airbag light
CEL and ABS lights are on, I did an initial autoscan, cleared, cycled, rescan, and was clear. Put in to gear, backed up, abs and cel came back on and I scanned again and the results are what I posted from the 3rd scan. Thank you for the link, time to start reading. Hopefully I get this figured out
Tdijarhead
Lawrenceville PA
Check fuse # 9, pull it and replace it. It's a 5 amp I believe.
Screamingdeal
Mac
I checked the ABS fuse and it's fine, no coms with abs module.
Charged battery overnight. Cleared codes, CEL off no Faults.
Abs light is still on. Fuse good. Going to keep troubleshooting
Screamingdeal
Mac
Gonna have to hit the store tomorrow for some fuses. I let the car run for a bit and decided to go for a drive to see if the brakes acted funny. Once I left the driveway the ABS light went off, hasn't come back. No codes. No lights. Magic. Thanks for the help. I'm hoping this isn't an Intermittent issue. I'll replace the fuse, probably do a parasitic draw test and maybe a battery test as well.
Tdijarhead
Lawrenceville PA
Sometimes that fuse just needs to be reseated, assuming you removed it to check it? I just helped a girl who bought a 2000 beetle gasser with the abs and related lights and no comm to abs module. I pulled the #9 fuse and it was very obviously blown. Once it was replaced the lights all went out.
Screamingdeal
Mac
Yeah, I pulled it and did a continuity test on it. It was good. I reseated the fuses in the side compartment and on top of the battery. I haven't been driving it because of the ABS light. So I'm going to start driving it more and see what happens. The battery being fully charged and clearing codes has seemed to fix the issue so far. VCDS was def worth it,
