osomphane
As an alh engine that can run on both wvo and svo?
Can you clarify what you are asking?? What are you looking to do?osomphane said:If WVO is purified, does that mean that you can mix SVO and WVO in a single fuel tank?
The nature of this question suggests that you have no clue what you are getting into. READ THE STICKY THREADS.osomphane said:If WVO is purified, does that mean that you can mix SVO and WVO in a single fuel tank?
osomphane said:I was pondering the feasibility of a new project car that would utilize a modified alh engine and fuel system (single-tank). I know what wvo and svo are, but you are right, I haven't read through everything to find if they can be interchangeable with each other (assuming wvo is filtered)...
It appears that a dual-tank is recommended with one of the tanks used for diesel. However, if I want to burn wvo and svo together, would I need 3 tanks?
