Nate,
So is there a way to check this function? I have been going through about 1 quart of oil every 2000 miles. compression is 490x4, my turbo seems fine. No play in the shaft in any direction, no oil in the bottom of the boost side housing, though I do have oil in the IC (just a 1/8" or less film on the bottom). blows blue smoke periodically when I step on it. I have no leaks whatsoever. I blew a rear main seal a while back and I suspect it was from veg oil contamination of the CC oil. I run a Greasecar WVO kit. My concern is that the same contamination screwed up my valve stem seals as well. I know that these do not normally leak oil since there is rarely vacuum under the valve cover, but I have been wondering about the vacuum under boost pulling oil vapor through the CCV, especially if the valve stem seals are bad. I do 120 miles a day on the highway and boost a lot, followed by stop-and-go traffic as I get into Denver. The CCV seems to be an empty chamber, free airflow in both directions. I am going to install a trap, but time, time, time......
Any way to check the CCV function (besides "borrowing" one from a co-worker ;-)
Thanks,
