This is my first post. I just registered here for the primary purpose of being able to say a HUGE thank you to the people who contributed to this thread. It’s benefit to me was immense.
My local shop would have been quite happy to hit me with a 4-digit bill for installing a new injection pump, to cure my fuel leak issue. Using the parts, tools, information, & methods described here, I was able to do what needed to be done for a 2-digit price tag.
I was fortunate. My only leak came from the top gasket on the pump. After a little clean up, I removed 4 bolts (including the special anti-tamper bolt), let the fuel dump into a pile of paper towels, changed the top gasket only, replaced the 4 bolts & was done. I didn't need to mess with the quantity adjustment. I didn't need to do the JB weld trick. I didn’t even seem to need to purge the air out of the pump. I just turned on the key, let the lift pump run for a minute or so, then started the car & let it idle for a few minutes before taking it for a test ride. Everything seems OK. My 15ish drops per minute leak is gone & my motor runs as well as it ever did.
Thank You Very Much,
Jim
