fruitcakesa
Isn't Hans Autoparts one of Prothe's bogus VW parts sites?First a big thanks to everyone for the great content. This is my first post, but not my first time following the advise on this forum.
(The car: 2002 VW TDI Beetle, Automatic, w/ 245k miles. Me: minimally proficient with a wrench, but learning.)
I have performed the seal change described in this thread, and am now being told I need a new IP. Here's the back story: I observed the IP leaking at one of the two top seals, and I changed the seals as described in the thread. I don't have a vag-com, so I adjusted the idle based on sound and prior alignment. The car ran fine for a week, and then I noticed that the serpentine belt was missing about 20%. I put the car into my (usually trusty) vw mechanic for a timing belt change (it was time.)
(First sign of issues...) When I picked up the car, it cranked odd. I thought it wasn't going to crank, but then it did and ran fine. This odd, delayed start persisted for two weeks until one day
(second sign...) it simply stopped running while I was going down the road. The engine just stopped, and would not start again. I towed it back to my mechanic, and they were able to restart it after cracking the injectors and bleeding out some air. They also pointed out that the IP was still leaking and suggested that the leak was the source of air (and why the car stopped.)
Not wanting to pay someone who knows what they're doing to fix it, I decided to change the head seal on the IP by following the Diesel Geek you tube videos. I had observed the leak from that joint, and was sure that was needed regardless of it being the source of air in the injector lines. The seal change went as planned, and I 'think' I did it without any harm to the IP. The only thing odd I ran into was the (these are not the right names) collar with the dimple for the throttle rod that comes from the top assembly... that collar was stuck into the plate on the left, on the inside of the IP. I had to put a little force onto it to slide it back to the right where it would accept the throttle rod. When I did, it seems to slide and spin completely freely. I closed everything back up, used my new mityvac to prime the pump, bled the injectors, and cranked.
(third sign...) I was never able to get a good idle. I bumped it left, right, a tiny bit and too much. I had run overs (one persisted even after I pulled the key out!) For the life of me, I could not get a steady idle. Again, I do not have a vag-com, so I ended up leaving it in a very rough idle state with the intent of taking it to the mechanic to get the timing adjusted. The mechanic didn't have time for 4 days, and I drove it the first 3. It ran fine when given gas, just idled very rough.
(forth sign...) On day 3 it died again, just like before, when we blamed air in the lines. However, now all of the seals are good and there is no visible leak. I bled the injectors and it started (after about 4 rounds of bleeding.) I left it running while I stepped inside to wash my hands, and when I came back out it was dead again. Bleeding didn't seem to work, so I ended up having it towed again to the mechanic.
Finally... The mechanic is telling me it needs a new IP. Here's the diagnosis:
NO START--BLED FUEL SYSTEM-AIR IN SYSTEM FROM WHEN CUSTOMER REBUILT PUMP.
--GOT VEHICLE RUNNING - RUNNING ROUGH. CHECKED GLOW PLUGS AND OTHER SYSTEMS.
CYL#2 GLOW PLUG IS FAULTY BUT NOT CAUSING VEHICLE TO RUN ROUGH.
--CHECKED INJECTION PUMP TIMING - RUNNING RICH AND SMOKING BAD. INJECTION
TIMING IS ALL OVER. RETARTED-ADVANCE-AND DEAD ON 35-60----INJECTION PUMP FAULTY.
Their price aside ($2200), does this sound like a bad Injection Pump issue? I can't help but wonder if the timing was off from when they did the timing belt. Particularly since the leaking IP was not an issue for months prior to getting the timing belt changed (it had been leaking awhile.) Or, did I just demonstrate that sometimes it's better to pay someone with experience to do the job right?
Thanks in advance for any and all advice!!
PS: Assuming I need to replace it, I'm planning to go with a rebuilt IP from hans autoparts. $730-$300 core = $430 net cost. Much less than the $1460 the mechanic quoted (oem). With nearly 250k miles on the car, I'm not about to drop 2k on oem.
Be careful here as Prothe is well known for his junk parts.
