ejallison1
- Joined
- Apr 28, 2010
- Location
- Kansas, Illinois
- TDI
- 98 Jetta TDI AHU, 97 Passat TDI AAZ, 04 Golf TDI PD, 01 NB TDI ALH
I am going to attempt a how to on the way I replaced the outer intermediate shaft bearing on my 97 Passat. Usual disclaimers that this is how I did it and your results may vary-proceed at own risk.
This car has 230xxx miles and not infrequently I notice that the low oil pressure light (blue flashing) is on for a few seconds after initial start-up. Am not a mechanic but have read on this forum that these bearings can be the more likely cause of low oil pressure. Oil pumps and rod bearings did not seem to be the most common culprit-these bearing did. I plan to keep this car a long time so did this as a preventative maintenance item. I do not have a mechanical oil pressure gauge on this car so I can not tell you before and after PSI-just in there already so why not do it.
The ideal time to do this is when replacing both the clutch and timing belt-so review those how to's on tdiclub.com and/or myturbodiesel.com. I did the engine and trans mount at the same time, which is necessary to remove the trans for a new clutch-at least the way I did it. I read all the how to's on the clutch replacement and I found it more simple to remove the subframe (k-frame) in order to get the trans out for clutch replacement. I highly recommend that you both heat and PB blast the subframe bolts prior to removing. I had one bolt snap off and it was a bear getting it out. Oil pan has to come off with this method.
During this procedure I left the front engine mount attached-no reason just hadn't done it yet. With the trans out and the engine supported with a harbor freight lift you can lower the engine enough to pull the intermediate shaft completely out exposing the outer bearing.
