Installing a EBJ transmission on a ALH that had a EGR.
FluffySmooth
Georgia, USA
2003 Alaska Green Jetta ALH TDI sedan 180,000 miles 02J 5spd transmission (aftermarket injectors, unsure of brand)
Can this be done? My car currently has a EGR transmission and I am looking into getting a different transmission. Do the EBJ's work on my car that previously had a EGR on it? I think I read somewhere a long time ago that the shift linkage ends are different, but works fine otherwise. Can anyone confirm or deny this? Will I have to move the linkages over? Thanks in advance.
Nero Morg
OR
The way the linkage attaches should be the same as the EGR coded trans, if it's not, swapping the tower isn't that hard. Otherwise rest of trans is a direct bolt up.
pkhoury
That guy with the goats
Mountain Home, TX
2013 JSW, 2 x 2002 Golf, 1995 F450 7.3L
Shouldn't be a problem. I think I bolted up an EUH at once point to an ALH, because I wanted the .746 5th instead of the .759 of the EGR. No changes otherwise.
