burn_your_money
This is a working theory and I would appreciate some input from the electrically inclined people in the group. Specifically those with a silly scope.
This is related to the "16705 - Engine Speed Sensor (G28) P0321 - 000 - Implausible Signal - MIL ON" code but also long cranking.
When the starter draw is excessively high, it creates a stronger magnetic field. This field induces noise into the crank sensor wires (that run directly on top of the starter solenoid). Because the crank sensor sends a weak signal by design to the ECU (no 5v reference signal) it doesn't take much noise in the wires to confuse the ECU. I suspect that this is why BEWs are notorious for long cranks, especially compared to the BHW. When the starter first starts turning, the most power is needed, and therefore the magnetic field is the strongest. Once the engine is turning over faster, the field diminishes and the ECU is able to read the crank sensor signal and begin firing the injectors. I suspect that the ECU doesn't throw the crank sensor code until the crank sensor misses a certain amount of readings, which is why a code isn't immediately thrown. This may also explain why extended cranking can cause the G28 implausible signal code to get thrown. The simple solution would be to move the wiring harness further away from the starter and that should result in faster startups. Of course, having a good starter and battery will also help reduce cranking time.
Can anyone prove or disprove my theory?
