truckerdave397
What is the proper way to torque the front wheel bearings on a 2003 TDI Jetta? I had mine replaced by what I think is a good mechanic. The right side is doing fine. The left side has failed twice it 3 months. These are National bearings. Mechanic is telling me that they over torque them then back off the nut then retorque to a setting. I have two new bearings coming from ID parts tomorrow. I also have heard that these should be torqued to 125 ft pounds only, run for a week then retorqued to 125 ft pounds. Has anyone else had issues with premature bearing failure? If so what was the cure?
