I need help just did motor swap cause mine blew I got everything hooked up except one wire. It’s on the passenger side by the headlight is a 90 degree connector 2 wires solid brown and brown and red. Is part of the headlight and map sensor harness. Anyone know where the other end plugs into? I know it’s around the ac port but I need to know where the other end goes to because I removed the whole front clip and harness out of the way and I can’t seem to locate the other end of the connector.
