NeXTstep guy
My 2003 Jetta TDI won't start. It's at the local CanadianTire right now and I'd appreciate some TDI guru advice...
My wife drove the car twice yesterday and it was fine. The third time, it wouldn't start, there were cranking sounds, but no starting.
We checked the anti-shudder valve and that is not the problem.
It might be battery related, but I am not sure about that part. (Sorry for the long battery story...)
- when I first looked at the battery, it was a bit below 12 volts. This is on a 7 year old interstate 130Ah battery. We haven't had any starting problems at all until yesterday.
- We got a boost (donor car was running), drove 15 minutes to the in-laws to borrow the battery charger. It started fine at the in-laws and drove another 15 minutes home.
- I looked at the cells, and only 1 cell was a bit low.
- We hooked up the intelligent charger overnight and it stopped charging sometime in the night. When I disconnected the charger, my voltmeter said it was at 12.25 (12.29?) volts.
- I tried starting and it would crank, but not start. My odb reader said that my battery was at below 12 volts. (Sorry don't remember voltage).
-get another boost. Could not start with donor car off. When donor car was running we started.
I am at Canadian Tire right now. They attempted to boost with their battery and had trouble. Getting crank sounds, but no starting.
The plan is to check out the charging system, and to replace the battery.
Does that make sense, or is there anything else we should try? (The InterState battery is a 85 month warranty battery and we are somewhere around the 90-95 month mark.) I can't figure out why I can't start it, aside from the checking the anti-shudder valve.
RWW
RWW
