RoundHouse
- Joined
- May 23, 2001
- Location
- Ga USA
so this morning in Atlanta the temp was in the low 30s
01 Beetle wouldnt fire.
I checked with a test light and the GPs stay on for about 7 seconds,
go off and dont come back on.
I checked with a test light connected to the battery positive and GP harness removed and the tip of all 4 plugs are grounded,
so I assume they are working
after cycling the ign switch a few dozen times and running the starter long enough it finally cranked,
any ideas?
check engine light is not on.
Im guessing the temp sensor is telling the engine the GPs are not needed ?
how do I check the temp sensor?
the hillbilly in me just says install a manual spring loaded button,
thats how I fixed my old F-350
and how I did my 1KZT toyota transplant into my 4 runner
instead of spending thousands on new relays, sensors, wiring harness etc
hold the button in for 5 seconds and hit the starter.
but I assume the defective temp sensor is also causing other problems that I cant see?
any ideas?
