bhtooefr
OK, I've already posted this to TeamSwift and The Car Lounge (related to the Whoretex)...
Here's the deal. 40 MPG isn't enough. Heck, 50 or 60 MPG isn't enough.
Give me 80 or 90 MPG.
Unfortunately, the Lupo 3L TDI isn't available in the US. And, even if it was, I wouldn't be able to afford it.
So, I have to make my own.
What car did we have in the US that was known for being lightweight, relatively aerodynamic, and super fuel efficient?
I've actually looked up the specs... A stock Geo Metro is slightly worse when it comes to aerodynamics than a Lupo 3L TDI, but it weighs 200 pounds less.
So... that leaves an engine. Which engine, is the question...
I'm thinking Kubota D950. And there's a reason. I've got four of them, three are in non-running tractors, and one is in a derelict wreck that'll never be usable and has very little useful parts.
http://media.putfile.com/Kubota-D950-Startup <-- video of the running D950 starting... yes, that's a lot of smoke. I suspect that that engine needs a reringing.
So, today I've been fighting with the engine in the derelict chassis. Got oil, got coolant, got some fresh fuel and additivized (hasn't been run in roughly 2 years), and threw a battery on. Tried to crank and... nothing. Turns out, the ignition switch was busted, so I got 12V to the starter, and all that jazz. After various attempts at getting more juice to it, I finally got it turning. Got tiny puffs of grey smoke, but no fire.
Anyway, that's not what this thread is about. That's a minor issue.
I need to know if anyone can recommend companies that can make a custom adapter plate, engine mounts, and other necessary stuff to connect this engine to a Suzuki tranny.
It uses a SAE #5 bellhousing, FWIW...
