racerxtdi
So I purchased my Jetta in Feb 2011. It had 52k and put an additional 85k on it myself.
A few weeks ago, my turbo seal blew and filled my engine with oil. This had a cascading effect very similar to a hydro-locked engine. I was stuck in traffic and was forced to keep driving. When I finally was able to pull over the engine seized and would not turn over. I pulled the glow plugs and it still will not crank. So after careful consideration it's time to move on.
I included a picture of the car and under the hood. But for individual parts pictures send am a DM and your cell#.
All parts are preferred pick up but will ship for a few $$$. If you need something not listed DM me. ALL PARTS ARE AS IS.
But will help if there is a problem! Best offers always work just no salt on my wounds...
Front 288mm and Rear 232mm Rotors Extreme Drilled (Upgraded 1.8T VR6) NIB 4 Rotors | 200 |
Akbono Front 288mm and Rear 232mm Brakes (Upgraded 1.8T VR6) NIB | 120 |
Full Auto to Manual Swap with .658 5th and Audi Short Shifter (Petals, Axels, Shifter, Tranny) Less Clutch and Flywheel Sold and Picked Up | |
(5) Alloy Rims with 16" Falken ZE950 V Rated Tires 5k wear (Rims with High Performance Tires) Sold and Picked Up | |
Ross Tech Hack 11.11 USB (with Storage and Software) Version Locked USED (Who Doesn't Hack) Sold and Picked Up | |
TDI MAF Pietersberg Sensor LNIB (Good to have a Spare) Sold and Picked Up | |
10mm Rear Spring Lifts NIB AutoTECH (Kim Kardashian Will Be Jealous of You Butt Lift) Sold and Picked Up | |
4 Bar MAP NIB Bosch (Only For Boosted Big Boys 30psi and Up) Sold and Picked Up | |
Pop Off ALH Engine Cover Kit (each) I have 2x (Should of Come From the Factory) Sold and Picked Up | |
Poly Energy Suspension Rear Spring Replacement Bushing RED Sold and Picked Up | |
11mm IP Pump Auto 187k USED (Bolt on Power) SOLD and Shipped | |
Husky Mats (Step In All the $h!t You Want) SOLD and Shipped | |
(2) Rear Hubs FAG NIB Price each SOLD and Shipped | |
VR6 Airbox USED SOLD and Shipped | |
Front Grill OEM Silver USED SOLD and Shipped | |
VR6 MAF USED SOLD and Shipped | |
South Bend Stg3 Daily Clutch & Flywheel 7K Wear SOLD and Shipped | |
Audi TT Solid Lower Control Arm Bushings 2x Priced for Both MAHLE SOLD and Shipped | |
Teflon Fuel line Kit (Serious UPGRADE) SOLD and Shipped | |
3.2 VR6 Heat-Exchanger Oil/Water (Faster Engine Warmup) SOLD and Shipped | |
ARP Head Studs NIB 1.9 ALH (No You Can Hold That Boost) SOLD and Shipped | |
(2) Rear Hubs FAG NIB Price each (Think Oversized Figit Spinners) SOLD and Shipped | |
CTS Turbo Motor All 3 Mounts 60 Durometer (Fixes Your Stiffness Problem and She Will Never Know) SOLD and Shipped | |
HotchKiss Rear Sway Bar 23mm NIB SOLD and Picked Up | |
DC Sports Strut Brace MK4 NIB SOLD and Picked Up | |
BilStein Rear Shocks B6 NIB SOLD and Picked Up | |
Moog Rear Springs NIB SOLD and Picked Up | |
Profidiesel 304 SS Turbo Back Exhaust 2.5" with Res-Cat (PA State Inspection Passed) Pickup Only SOLD and Picked Up | |
Front BilStein Struts B6, Moog Springs, and Heavy Duty Strut Mounts 5k wear SOLD and Shipped | |
11mm Auto Injectors Non Square Plug 187k USED SOLD and Shipped | |
NSB Boost Gauge and Pod SOLD and Shipped | |
10mm IP Pump with 137K miles SOLD and Shipped | |
BvG Oil Catch System OEM Look Oil Catch Can SOLD and Shipped | |
ECU and Gauge Cluster with Flashzilla STG3 Malone Tuned with digital files (RFID chipkey included) SOLD and Shipped | |
PP520 Nozzles DBW Calibrated 2003 Square Plug 27k Wear SOLD and Shipped | |
2 Micron Fuel Filter Nicktane Style with 3-4 CAT IR 0750 Filters NIB SOLD and Shipped | |
2.5 Bar MAP NIB SOLD and Shipped | |
Bosch Alternator 90 Amp NIB SOLD and Shipped | |
Upgraded Intercooler TACOTACO NIB SOLD and Shipped | |
Upgrades IC Pipes 2" upper with 1.8T Lower Pipe Hoses and Clamps NIB/USED SOLD and Shipped | |
Seat Cupro R Rear Bushings NIB SOLD and Shipped | |
PD150 Intake USED SOLD and Shipped | |
PD150 Tip USED SOLD and Shipped | |
PD150 EGR SOLD and Shipped | |
