NHgranite
For sale is my very clean and tastefully modified MKIV Jetta.
Over the years, I have spared no expense in upgrading it and have spent significantly more $$$ than what I'm asking. But once you drive it, you'll understand that this has been set-up very well. Fuel efficiency is excellent (best ever is 57mpg) (avg with summer fuel 52mpg).
The combination of power mods and quality of the tune makes this a really *Fun Car to Drive*.
Total mileage on the body is ~167,000. Mileage on all the wear items (engine, trans, brakes, suspension, paint, etc) is less than 5,000 miles.
Asking price: $9900.00
Engine Mods
Rocketchip RC4+ ASV tune
VNT 17/22 Turbo
PP520 nozzles
11mm pump
Rosten H-beam rods
ASV 79.5 pistons
APR head studs
Colt2 cam
Ported&Polished head by MrChill
PD lifters, Dual-springs w/ Ti lifters
2.5" Matt Whitbread downpipe
2.5" SS full exhaust with turn-down tip
(no cat, 1 aeroturbine muffler)
PD150 Turbo Intake Pipe (TIP)
PD150 intake manifold
Race pipe
R32 airbox & snorkel
Tyrolsport SMIC
IDparts upper & lower charge pipes
PD130 oil cooler
PD lift pump
Alum "old Navy" breather w/
BMW cyclonic breather mod
Amsoil bypass 2nd oil filter
*estimating approx 165-170hp.
5-speed Transmission Mods
Wavetrac diff
3.16 R&P final drive
5th gear oil mod
Southbend Stg2 Endurance clutch
Raxels
108mm flanges
Suspension Mods
H&R sport springs
(Shine 225/180 springs available)
Koni Yellow shock/struts
(BilliHD available)
Shine Rear sway bar
Audi TT cast lower control arms
Audi TT Spindles & front wheel bearings
New wheel bearings in rear.
Rear calipers rebuilt.
Front sway bar removed
* The car looks better w/ the H&R springs, but handled *better* with the Shine. I have both and we can discuss details.
Wheels
Summer: 16x7 alloy w/ *new* Michelin Pilot Sports
225/50R16
Winter: 15x6.5 alloy w/ 80% tread Nokians
196/65R15
* This car mostly sits inside during the winter. Overall condition is 9 out of 10.
However, the wavetrac & snow tire combo is very solid in the winter time.
Brakes
288mm front rotors
1.8T calipers
Hawk HPS pads (front & rear)
Upgraded OEM emer brake cable
Supporting Mods
Frost heater w/ external plug
Boost/EGT gauge
Alum DG skid plate
"Big Three" Bat/Gnd cables
Euro light switch
Rear fog light
Euro rear tail lights
E-code blacked Headlights
5-brake light mod
LED light strip in trunk
Fuel tank vent mod
GTI Recaro seats
R32 three-spoke steering wheel
"shaved" hood emblem
PD rear trunk
I have the Hella DE fog lights, grills & relays.
Haven't installed them (yet).
Stereo
Pioneer DEH 80-PRS "active" headunit
Focal V30 component set (3/4" & 6.5")
Arc Audio 10D4 sub in custom fiberglass sealed corner box
Arc Audio 4ch & Mono amps mounted on custom amp rack
Proper sound dampening throughout.
* This set-up sounds *excellent*
The car has been worked on by two TDIclub gurus and is in top running condition. Everything was done correctly and it shows. The only reason I'm selling it is because I have a new project car.
Send me a PM to discuss details.
Thank you.
Engine Mods
VNT 17/22 Turbo
PP520 nozzles
11mm pump
Rosten H-beam rods
ASV 79.5 pistons
APR head studs
Colt2 cam
Race pipe
Tyrolsport SMIC
PD130 oil cooler
PD lift pump
Wavetrac diff
5th gear oil mod
Raxels
108mm flanges
Suspension Mods
H&R sport springs
(BilliHD available)
Shine Rear sway bar
Wheels
225/50R16
196/65R15
Brakes
288mm front rotors
1.8T calipers
Supporting Mods
Boost/EGT gauge
Alum DG skid plate
Euro light switch
Rear fog light
5-brake light mod
Fuel tank vent mod
GTI Recaro seats
PD rear trunk
Stereo
Thank you.
