I'm trying to use this software with my Ross-Tech HEX+CAN cable. The laptop is a Lenovo P51. On plugging the Ross-Tech cable in, device manager shows it to be only in one of the Universal Serial Bus controllers section. It comes up as Ross-Tech Direct USB Interface. In the Device Manager under Ports(COM & LPT) there is only the Intel(R) Active Management Technology - SOL (COM4) entry.
I can run the software but when I do, I get this output no matter which COM port I put in the command line. I tried with COM2, 3, 4,9.
PS C:\Users\jtabasz\desktop\vcds\kw1281test_Win10> .\kw1281test.exe usb 10400 17 DumpEeprom 0 2048
KW1281Test 0.56-beta (
https://github.com/gmenounos/kw1281test/releases)
Args: usb 10400 17 DumpEeprom 0 2048
Unhandled exception: System.TypeLoadException
at System.Diagnostics.Process.set_PriorityClassCore(ProcessPriorityClass value)
at System.Diagnostics.Process.set_PriorityClass(ProcessPriorityClass value)
at BitFab.KW1281Test.Program.Run(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 53
at BitFab.KW1281Test.Program.Main(String[] args) in C:\Users\gmeno\src\kw1281test\Program.cs:line 26
I tried to "Update Driver" on the USB controller with the Ross-Tech label but my W10 comes back with "Already using the best driver for this application" type message. Anyone else see this issue and work through it?
Thanks,
JT
